yhy.xilinx
DSP library on VITIS
I want to use 2-D FFT implementation that comes with DSP library of VITIS. However, would it work on embedded platforms(such as zcu102-104-106 etc.)? or is it meant to work only on Alveo cards?
Thank you for your valuable time.
Tags (3)
florentw
Hi @yhy.xilinx
It will work on any 7-series/US/US+/Versal/Alveo devices. This is HLS code so you just need to package it as a HLS kernel to be used in a platform in Vitis
Florent
florentw
Hi @yhy.xilinx
Florent
