robinplc2
Debug the source code in VART/DNNDK samples - Vitis AI
Hello All,
So far, Xilinx has provided a lot of samples (VART/DNNDK) for writing the application code for various deep learning applications. if we take one of the c ++ samples and assume we have to learn how the pre/post-processing code works, Is there any quick way around to put these codes running on an IDE and we can easily debug through it for better understanding.
I am not sure how it works and thought about this when we can actually cross-compile these sample application programs in a host machine.
I would really appreciate  if some can help.
Robin
jasonwu
Hi @robinplc2 ,
You can try this one:
https://github.com/gewuek/vitis_ai_custom_platform_v1.2_tmp
The VItis application is compiled on Vitis GUI, you may try with TCF agent(UG1144).
Best Regards,
Jason
