[Decent] Cannot quantize custom model
I'm trying to quantize a model that consists in several dense layers followed by conv1d layers. When I run decent_q, it outputs the following warnings:
[DEPLOY WARNING] Node conv_0/BiasAdd(Type: BiasAdd) is not quantized and cannot be deployed to DPU,because it has unquantized input node: conv_0/bias. Please deploy it on CPU.
[DEPLOY WARNING] Node conv_0/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: conv_0/BiasAdd. Please deploy it on CPU.
[DEPLOY WARNING] Node conv_1/BiasAdd(Type: BiasAdd) is not quantized and cannot be deployed to DPU,because it has unquantized input node: conv_1/bias. Please deploy it on CPU.
[DEPLOY WARNING] Node conv_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: conv_1/BiasAdd. Please deploy it on CPU.
Another thing I don't understand is that the generated deploy_model.pb doesn't decrease in size compared to the frozen model, although it should because of quantized weights. It means that the Dense weights are not quantized.
Furthermore, when I run DNNC, I got the following error:
[DNNC][Error] 'Const' op should be fused with current op [BiasAdd] by DECENT.
The only "unusual" operation used in my model is this one, occuring after dense layers:
layers.Lambda(lambda x: tf.reshape(x, [-1, N, 1]))(estimators[index])
Any ideas?
Thank you,
Neutrinoxy
回复: [Decent] Cannot quantize custom model
You may want to take a look at supported network features by DPU:
https://www.xilinx.com/support/documentation/ip_documentation/dpu/v3_0/pg338-dpu.pdf
pg20, Table 7
Try --ignore_nodes to have them left unquantized during quantization.
@graces If using the --ignore_nodes command, will the compilation with DNNC still work well?
The reason that the size of the quantized frozen model is not reduced is becasue the 8 bit quantized weights are still stored as an FP32 value.
