Deploying model on ZCU102 board
 I have run my tensorflow model on the ZCU102 board using python API's for DPU. After evaluating the model on the board what are the steps for deploying the model onto the FPGA? Also, I am using DNNDK v-3.1.
Re: Deploying model on ZCU102 board
Hi @jbond1007 ,
For custom design I would suggest the following steps:
1. Run demon for DNNDK examples
I recomend these examples because they are using low level API and have more detailed code and can be easiler modified to suit your own design
2. Use DNNDK to training your own model into ELF
Following the DNNDK tutorial. Acutally for now the models we provided are just reference design. We don't provide details of the trainng flow. So for a custom design I suppose you would like to train your own models
3. Following the steps in https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/DPU-Integration to create your own platform.
Xilinx dev board or your own board.
Best Regards,
Jason
Hi @jbond1007 ,
I am afraid that I don't quite your question.
If you run your model on ZCU102 I believe that you have deploy the model on FPGA.
If you mean creating a DPU design and compiling PetaLinux images I would suggest you to refer to:
If you mean change your own model(Caffee or TensorFlow) into kernel ELF I would suggest you to refer to the flow in:
https://www.xilinx.com/support/documentation/user_guides/ug1327-dnndk-user-guide.pdf#page=37
Hope this is what you want. :-)
Best Regards,
Jason
Thanks for your reply.
I have successfully generated .elf files for my tensorflow model and also have run it on the board. My question is what should be done to deploy this model in live production environment.
Now I have a python code for interacting with the DPU which was meant for evaluating the model on the board similar to "miniresnet.py" from the samples in the DNNDK files. I have tested the model with it and it ran successfully, but what are the next steps for putting this model in production where live images will be captured and the model classifies them?
Hi @jbond1007 ,
Best Regards,
Jason
Hi @jbond1007 ,
For "live images will be captured and the model classifies them" I believe that there should be custom design input here.
And we do have some references but most of them are written in C code like this web camera demo:
https://github.com/Xilinx/Edge-AI-Platform-Tutorials/blob/master/docs/DPU-Integration/reference-files/files/face_detection/face_detection.cc
Python should work but you may need to find some reference design or write the code by yourself.
Best Regards,
Jason
