06-08-2020 07:15 PM - edited 06-08-2020 07:16 PM
Hi everybody,
I have a graph which uses convolution transpose:
layers += [ torch.nn.ConvTranspose2d(inch, output_channels, kernel_size=4, stride=2, padding=1), torch.nn.BatchNorm2d(output_channels), torch.nn.ReLU() ]
It was trained on Pytorch then converted to Tensorflow using Keras backen (https://github.com/nerox8664/pytorch2keras), the final graph would be like this:
Quantize this graph with Vitis-AI 1.1 gives me an error which says that the FusedBatchNorm cannot be quantized:
INFO: Checking Float Graph... INFO: Float Graph Check Done. INFO: Calibrating for 10 iterations... 100% (10 of 10) |###########################################################################################################################################################| Elapsed Time: 0:00:07 Time: 0:00:07 INFO: Calibration Done. INFO: Generating Deploy Model... 2020-05-29 01:20:02.384739: F tensorflow/contrib/decent_q/utils/deploy_quantized_graph.cc:768] Check failed: scale_node.attr().count("wpos") [DEPLOY ERROR] Cannnot find quantize info for weights: 240_1/FusedBatchNorm/scale Fatal Python error: Aborted Current thread 0x00007f076c210740 (most recent call first): File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/contrib/decent_q/python/quantize_graph.py", line 232 in CreateQuantizeDeployGraphDef File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/contrib/decent_q/python/decent_q.py", line 293 in deploy_frozen File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/contrib/decent_q/python/decent_q.py", line 327 in quantize_frozen File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/contrib/decent_q/python/decent_q.py", line 576 in main File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/contrib/decent_q/python/decent_q.py", line 780 in <lambda> File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/absl/app.py", line 250 in _run_main File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/absl/app.py", line 299 in run File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/python/platform/app.py", line 40 in run File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/lib/python3.6/site-packages/tensorflow_core/contrib/decent_q/python/decent_q.py", line 781 in run_main File "/opt/vitis_ai/conda/envs/vitis-ai-tensorflow/bin/vai_q_tensorflow", line 11 in <module> Aborted (core dumped)
After remove BatchNorm with following code:
torch.nn.ConvTranspose2d(inch, output_channels, kernel_size=4, stride=2, padding=1), #torch.nn.BatchNorm2d(output_channels), torch.nn.ReLU()
The graph could be quantized but parts of the conv_transpose layer cannot be deployed on DPU:
INFO: Checking Float Graph... INFO: Float Graph Check Done. INFO: Calibrating for 10 iterations... 100% (10 of 10) |###########################################################################################################################################################| Elapsed Time: 0:00:10 Time: 0:00:10 INFO: Calibration Done. INFO: Generating Deploy Model... [DEPLOY WARNING] Node 217_crop_1/strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 217_crop_1/strided_slice/stack. Please deploy it on CPU. [DEPLOY WARNING] Node 218_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 217_crop_1/strided_slice. Please deploy it on CPU. [DEPLOY WARNING] Node 219_crop_1/strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 219_crop_1/strided_slice/stack. Please deploy it on CPU. [DEPLOY WARNING] Node 220_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 219_crop_1/strided_slice. Please deploy it on CPU. [DEPLOY WARNING] Node 221_crop_1/strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 221_crop_1/strided_slice/stack. Please deploy it on CPU. [DEPLOY WARNING] Node 222_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 221_crop_1/strided_slice. Please deploy it on CPU. [DEPLOY WARNING] Node 227_1/mul(Type: Mul) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 224_1/Tanh. Please deploy it on CPU. [DEPLOY WARNING] Node 209_crop_1/strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 209_crop_1/strided_slice/stack. Please deploy it on CPU. [DEPLOY WARNING] Node 210_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 209_crop_1/strided_slice. Please deploy it on CPU. [DEPLOY WARNING] Node 211_crop_1/strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 211_crop_1/strided_slice/stack. Please deploy it on CPU. [DEPLOY WARNING] Node 212_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 211_crop_1/strided_slice. Please deploy it on CPU. [DEPLOY WARNING] Node 213_crop_1/strided_slice(Type: StridedSlice) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 213_crop_1/strided_slice/stack. Please deploy it on CPU. [DEPLOY WARNING] Node 214_1/Relu(Type: Relu) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 213_crop_1/strided_slice. Please deploy it on CPU. [DEPLOY WARNING] Node 225_1/mul(Type: Mul) is not quantized and cannot be deployed to DPU,because it has unquantized input node: 216_1/Sigmoid. Please deploy it on CPU. INFO: Deploy Model Generated. ********************* Quantization Summary ********************* INFO: Output: quantize_eval_model: ./quantized_output_nhwc/quantize_eval_model.pb deploy_model: ./quantized_output_nhwc/deploy_model.pb
So does Vitis fully support conv2d_transpose layer???
Mismatch information
Bellow are supported layers from Vitis-AI 1.1 documents (https://www.xilinx.com/support/documentation/sw_manuals/vitis_ai/1_1/ug1414-vitis-ai.pdf, page 59 or at https://www.xilinx.com/html_docs/vitis_ai/1_1/yhx1576126008370.html):
It says that ConvolutionTranspose layer is supported.
But some others have confirmed it is not supported layer:
https://forums.xilinx.com/t5/AI-and-Vitis-AI/Support-for-conv
Thank you!
06-09-2020 08:49 PM
For BatchNorm, ensure that it's in inference phase when freezing the graph. e.g. For model susing tf.keras, call tf.keras.backend.set_learning_phase(0) before building the graph.
For torch.nn.BatchNorm2d, the parameter looks to be affine=False.
ConvTranspose2d looks to be supported per UG1414. From the warning, operation StridedSlice cannot be deployed to DPU. Would you please try defining --output_nodes prior to the StridedSlice operator?
