rezhirad
ERROR: Failed to open /dev/xlnk
I was able to quantize resnet50 (tensorflow version) with decent tool and also could generate .elf with dnnc.
But now there is an issue when I try to run .elf file generated from CPU ELF object regarding Hybrid Execution. It doesn't matter if I compile it from SDSoC or DNNDK tool on the board, in both cases I get the error: Failed to open /dev/xlnk
It is clear that xlnk is the SDSoC kernel driver that helps with memory management, accelerator control, and data movement among other things; and this error occurs when the xlnk driver is not configured in the petalinux project or it is not included the xlnk fragment in the devicetree. But just for demo I took the already exising image from here: xilinx-zcu104-prod-dpu1.4-desktop-buster-2019-04-23.img.zip and it is obvious that xlnk is not configured in the petalinux.
Now the question is, how I can add the xlnk to the already existing image?
The next question is, why this problems occurs even when the code is compiled with the DNNDK tool on the board?
guo_bing
I'm also curious how to add other compents into a prebuild img, such as:
xilinx-ultra96-prod-dpu1.4-desktop-buster-2019-05-31.img.zip
