f.restuccia
Error generating the DPU hardware design
Hello Xilinx community,
I'm trying to create the hardware design of the DPU following the tutorial at:
https://github.com/Xilinx/Vitis-AI/blob/master/dsa/DPU-TRD/prj/Vivado/README.md
I followed all the steps reported in the tutorial.
Unfortunately, when I source the project to Vivado using the command
vivado -source scripts/trd_prj.tcl
Vivado reports the following error:
ERROR: [BD 41-1273] Error running post_config_ip TCL procedure: unexpected "," outside function argument list ::xilinx.com_ip_zynq_ultra_ps_e_3.3::post_config_ip Line 47
How can I solve the problem?
davidxu
Hi @f.restuccia
Which Vivado version do you use?
Vivado 2020.2 is recommended.
f.restuccia
hi @davidxu, thank you for your answer. I'm using Vivado 2020.2 as recommended running on Ubuntu 18.04
f.restuccia
@davidxu I'm still having the same issue. Any hint to solve it?
davidxu
Hi @f.restuccia
I am sorry. I cannot reproduce your issue using Vivado 2020.2 on Ubuntu 18.04.
Obviously this is not a DPU problem, may be this is a tools problem, can you post this problem to other sub-forums?
