02-09-2019 03:13 AM
[DNNDK] Invalid mean value for DPU kernel. kernel name : anet_0
There is a error at run time,How to solve this problem?
Thanks!
02-12-2019 10:18 AM
hello
The invalid mean value might be due to a wrong setup in the prototxt file describing the CNN architecture. For the final step (compilation) the deployed.prototxt should have commented all references to the mean_file. Only the mean values should be present.
02-13-2019 01:20 AM
How can I modify this network?
layer {
type: "ImageData"
top: "data"
top: "label"
include {
phase: TRAIN
transform_param {
mirror: true
crop_size: 126
scale: 0.017
image_data_param {
source: "/home/aa/demo/Classification/train.txt"
root_folder: "/home/aa/demo/Classification/all-images/"
batch_size: 50
new_width: 126
new_height: 126
is_color: false
shuffle: true
layer {
type: "ImageData"
top: "data"
top: "label"
include {
phase: TEST
transform_param {
mirror: false
crop_size: 126
scale: 0.017
image_data_param {
source: "/home/aa/demo/Classification/test.txt"
batch_size: 25
new_width: 126
new_height: 126
is_color: false
02-13-2019 01:24 AM
02-15-2019 03:32 PM
@xxd137494375How do you set the mean value in float prototxt? Here below is an example -
layer {
type: "ImageData"
top: "data"
top: "label"
include {
phase: TRAIN
transform_param {
mirror: false
mean_value: 104
mean_value: 107
mean_value: 123
image_data_param {
# source: "./data/imagenet_256/calibration.txt"
# root_folder: "./data/imagenet_256/calibration_images/"
source: "/down/dnndk_2.08/common/dataset/imagenet/val.txt"
root_folder: "/down/dnndk_2.08/common/dataset/imagenet/val/"
batch_size: 10
shuffle: false
new_height: 224
new_width: 224
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
02-16-2019 11:41 PM
02-17-2019 02:30 AM
04-22-2019 07:49 AM
Not certain if this was resolved, sharing my experience just in case.
I ran into the same issue as you, with the following prototxt definition:
transform_param {
scale: 0.00390625
mirror: false
Note the 1/256 scale is for the binary input image, similar to what you mentionned.
I was able to resolve the issue by adding the missing "mean_value" value (just one, since this is a grayscale image (not rgb).
transform_param {
scale: 0.00390625
mirror: false
mean_value: 0
Hope this helps !
AlbertaBeef ;)
