Evaluating Tensorflow Resnet50 on Computer
I'm trying to evaluate the frozen graph for resnet50 using Tensorflow on my computer (Ubuntu 18.04.3). The evaluation itself works fine (using the "evaluate_frozen_graph.sh" script), but I'm getting extremely low testing accuracy, on the order of 0.001 for top1 accuracy. I was wondering if this is possibly due to the labels I'm using. In fact, I'm not sure exactly what labels should be used here. I'm testing my model on the ILSVRC2012 validation set, which doesn't have any labels, at least when downloaded from the suggested site (http://academictorrents.com/collection/imagenet-2012). Can anyone point me to where I might find the labels for this dataset in the format that is expected by the pretrained DNNDK resnet50 model?
Re: Evaluating Tensorflow Resnet50 on Computer
Hi @achempak ,
I double check the webpage. It seems that the calibration label file is not attached in that document. Sorry about that.
Actually I don't have a label file for all the images.
This is what I got here: about 4000 labels on ILSVRC2012_val dataset for calibration.
Please check the attachment to get the caibration label file for ILSVRC2012_val dataset.
Hope this can help.
Best Regards,
Jason
Hi @achempak ,
I would suggest you to refer to this AR: https://www.xilinx.com/support/answers/72804.html
You can find a lot of helpful information there.
Best Regards,
Jason
Hi @jasonwu , I looked at the link you posted, but I don't think it contains information to solve this problem. I was wondering how the ResNet network was trained (e.g. what were the labels used) such that I can use the same labels for testing. I may have missed something, though!
Hi @achempak ,
Hope this can help.
Best Regards,
Jason
Hi @jasonwu,
This is what I was looking for. Thank you!
