dikshantbisht
Fatal Error: No such file or directory for most of #include in cpp
After follwing Vitis-AI installation guide, when I'm trying to run build file, for any of the demo or samples, it's throwing error.
follwing are the errors
test_accuracy_yolov3_bdd.cpp:18:10: fatal error: opencv2/opencv.hpp: No such file or directory
#include <opencv2/opencv.hpp>
test_jpeg_yolov3.cpp:16:10: fatal error: glog/logging.h: No such file or directory
#include <glog/logging.h>
test_performance_yolov3.cpp:16:10: fatal error: xilinx/ai/benchmark.hpp: No such file or directory
#include <xilinx/ai/benchmark.hpp>
jheaton
It sounds to me like the Vitis-AI Libraries were not intsalled. You need to that as well as te Vitis AI Tools.
https://github.com/Xilinx/Vitis-AI/tree/master/Vitis-AI-Library
dikshantbisht
The main issue is coming when I'm running  "sh -x build.sh" command.
I have downloaded Vitis-Ai Library, and vitis-ai runtime image, but when I'm inside workspace the build command is throwing below fatal error. I'm not able to go past this step.
jheaton
This might be a docker issue.
I see you are running as sudo, but can you run docker without sudo?
docker run hello-world
If not, then you need to perform this additional configuration: https://docs.docker.com/install/linux/linux-postinstall/
dikshantbisht
Actually I already did those things, and I'm able to run hello-world command without sudo.
I'm not sure what i'm missing.
miner_tom
I am having the same issue as in https://forums.xilinx.com/t5/AI-and-Vitis-AI/Fatal-Error-No-such-file-or-directory-for-most-of-include-in-cpp/td-p/1067022
I am running Ubuntu 18.04, a clean install, just for this purpose. I have attempted to make this post as clear and as succinct as possible.
There are a few other things that I suspect concern an improper docker install to begin with.
First, in the directions to install the "vitis-ai-runtime image" at this site https://github.com/Xilinx/Vitis-AI/tree/master/Vitis-AI-Library  At
Setting Up the Host
Download the vitis-ai-docker-runtime image
I get only a page with "ERROR 404 Page not found" when I click on the link. So that link on that page is dead.
I had to go to the following page https://hub.docker.com/r/xilinx/vitis-ai and do "docker pull -a xilinx/vitis-ai. This seemed to work. The "-a" is necessary.
I made sure that I had configured docker properly for my user and can run "docker run hello-world" with non sudo.
I ran into some issues here https://github.com/Xilinx/Vitis-AI/blob/master/doc/install_docker/load_run_docker.md
# GPU Image must be built by user.
cd Vitis-AI/docker
./docker_build.sh
# After the GPU image is built, load it
./docker_run.sh xilinx/vitis-ai:tools-<x.y.z>-gpu
# i.e.
cd Vitis-AI
./docker_run.sh xilinx/vitis-ai:tools-1.0.0-gpu
My ./docker_build.sh failed, with some very cryptic error, that I could not begin to decode.
However,
./docker_run.sh xilinx/vitis-ai:tools-1.0.0-cpu
and
./docker_run.sh xilinx/vitis-ai:runtime-1.0.0-cpu
Actually ran without error.
Where I suspect things went wrong is in the UG1354 users guide.
After the docker image is installed, the cross compiler tools are stored in /opt/vitis_ai/
petalinux_sdk/.
After installation there IS NO /opt/vitis_ai/petalinux_sdk. I think that might be also the problem that I was having with "./docker_run.sh xilinx/vitis-ai:tools-1.0.0-gpu" because the error, several lines long, did start out with
 ERROR: Command errored out with exit status 1:
     command: /opt/vitis_ai/conda/envs/vitis-ai-caffe/bin/python
As far as I can tell, there is no /opt/vitis_ai/conda/envs/vitis-ai-caffe/bin/python directory that I can find.
And, of course, going into the samples/yolo3v directory and doing a ./build.sh I get
test_accuracy_classification.cpp:19:10: fatal error: opencv2/core.hpp: No such file or directory
 #include <opencv2/core.hpp>
compilation terminated.
test_accuracy_classification_squeezenet.cpp:21:10: fatal error: opencv2/core.hpp: No such file or directory
test_jpeg_classification.cpp:19:10: fatal error: opencv2/core.hpp: No such file or directory
test_jpeg_classification_squeezenet.cpp:20:10: fatal error: opencv2/core.hpp: No such file or directory
test_performance_classification.cpp:16:10: fatal error: xilinx/ai/benchmark.hpp: No such file or directory
test_performance_classification_squeezenet.cpp:19:10: fatal error: xilinx/ai/benchmark.hpp: No such file or directory
test_video_classification.cpp:19:10: fatal error: opencv2/core.hpp: No such file or directory
I am hoping that there is some solution.
Thank You
Tom
jheaton
@Tom
Are you running the cpu run time docker container when looking for /opt/viits_ai/petalinux_sdk ?
Try running the docker container first, i.e. <path to Vitis AI>/docker_run.sh /xilinx/vitis-ai:runtime-1.0.0-cpu
You should see somthing like this:
miner_tom
@jheaton
Thank you for your reply. Getting very close here.
I did as you recommended below, as in, "docker_run.sh xilinx/vitis-ai:runtime-1.0.0-cpu". I got the results below, and yes, after running the container, I was able to see the workspace directory with the other directories shown in your post. So far so good.
Then from UG1354:
4. Using Git, clone the corresponding AI Library from https://github.com/Xilinx/Vitis-AI.
$cd /workspace
$git clone https://github.com/Xilinx/Vitis-AI.git
I did that successfully, but under sudo, otherwise it would not work.
I ran into some familiar difficulty with the following next step.
$cd /workspace/Vitis-AI/Vitis-AI-Library/demo/demo_yolov3
$sh -x build.sh
Running the above without sudo resulted in a permission denied error. I expect that since the files are owned by root. I think that is because I had to do the git clone https://github.com/Xilinx/Vitis-AI.git as sudo. Otherwise it would not work.
Running the above as sudo resulted in the familiar "no such file or directory" error.
 sudo ./build.sh
demo_yolov3.cpp:16:10: fatal error: glog/logging.h: No such file or directory
I tried logging in as root but that resulted in another error.
I know that I am close.
Thank You again.
Tom
jheaton
If I understand correctly, it sounds like you cloned the repo, from within the docker container. I dont think you want to do that.
Just clone the repo first outside of docker, and then start the container.
miner_tom
@jheaton
Jim, than you again.
Doesn't the direction that you suggested to me contradict the UG1354?
$cd /workspace
The above implies that since that the git clone operaiton should be done in the /workspace directory, which does not exist unless the docker is running.
However the readme.md in the Vitis-AI directory says what you implied:
    * Clone the Vitis-AI repository to obtain the examples, reference code, and scripts. ``` git clone https://github.com/Xilinx/Vitis-AI
       cd Vitis-AI ```
     * Install Docker - if Docker not installed on your machine yet
     * Ensure your linux user is in the group docker
     * Load&Run Docker Container
I started from scratch, and deleted the Vitis-AI directory. I used the git clone and installed Vitis-AI at /.
cd Vitis-AI
/workspace
cd Vitis-AI-Library
cd demo
cd yolov3
ls
-rw-r--r-- 1 root root  228 Jan 29 05:14 build.sh
-rw-r--r-- 1 root root 4455 Jan 29 05:14 demo_yolov3.cpp
-rw-r--r-- 1 root root  978 Jan 29 05:14 readme
sh build.sh
/opt/vitis_ai/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/8.2.0/real-ld: cannot open output file demo_yolov3: Permission denied
Using sudo did not work either.
As always, I am greatful for your assistance.
Tom
dikshantbisht
Has anyone solved this issue yet?
miner_tom
@dikshantbisht @jheaton
No, I have not solved the issue. I have gone through every permutation that I can think of in loading docker, the docker image and Vitis-AI but nothing worked. My experiments are documented in previous posts.
I am still waiting patiently for someone that knows what is going on to provide a suggestion. If I had to guess, I think that since the software is so new, that there is a revision in process. At least, I hope that there is.
Tom
jheaton
@minor_tom
We have not seen this before. It is obvisously some kind of permisson issue.
One thing I notice is that the files are owned by root. Did you launch the docker shell under sudo?
Or were you running as root when you cloned the repo?
Here is what I see for the same files.
miner_tom
@jheaton
Jim, as always, I am completely grateful for your suggestions. Really.
I believe that I am coming close to some understanding. Close.
My permissions are the same as yours, so that does not look like the problem.
-rw-r--r-- 1 tom vitis-ai-users  228 Feb  5 15:09 build.sh
-rw-r--r-- 1 tom vitis-ai-users 4455 Feb  5 15:09 demo_yolov3.cpp
-rw-r--r-- 1 tom vitis-ai-users  978 Feb  5 15:09 readme
However, the error that I get when I run sudo bash build.sh (yes I have to run that as sudo) is suspicious.
demo_yolov3.cpp:21:10: fatal error: opencv2/core.hpp: No such file or directory
Of course, the workspace environment knows nothing of opencv and I don't know why I thought that it would. I have opencv4 installed, but not in the workspace environment. When not under the workspace environment I run opencv4 by
Python 3.6.9 (default, Nov  7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
But, I can't even invoke python in the workspace environment.
Does this mean that I will need to do a fresh install of opencv  and python, etc, in the workspace environment? When I exit the workspace environment, would all that I installed be lost?
Thank You again.
Tom
jheaton
The fact that you have to run as sudo indicates an issue with docker permissions.
If the following does not work without sudo:
Then you need to do the following post docker installation steps: https://docs.docker.com/install/linux/linux-postinstall/
I dont know if this is causing your exact issue, but I do know that having to run as sudo will break running the vitis ai tools docker container.
miner_tom
@jheaton
Thank you again.
My mistake about having to run ./build.sh in sudo. I don't.
Also, docker DOES run with "docker run hello-world".
But as my latest question from above, do I need to install opencv within the workspace?
Tom
jheaton
No, you shouldn't need to import opencv.
But you are not running the docker shell as sudo correct? :
miner_tom
@jheatonyou are indeed a genius. My problems were related to privileges all along. For some reason, after I ironed out the privileges I somehow was invoking the wrong docker shell. Your post reply showed me that.
It can't be stressed enough that everything needs to be done as a usr that is not root.
Thank You
Tom
dikshantbisht
@miner_tom  Can you please explain a little bit in detail what was the issue and how you resolved it ?
Dikshant
miner_tom
@dikshantbisht
Dikshant, There are a couple of things in the documentation that could be emphasized a bit better, and I am not 100% sure that everything is working correctly. For example, I was able to get this tools container docker shell running : "vitis-ai:runtime:1.0.0-cpu", but not "xilinx/vitis-ai:1.0.0-cpu" or "vitis-ai:runtime-1.0.0-gpu". But, be that as it may, the runtime tools container was sufficient for me to be able to compile the sample yolov3.
I am going to recommend that you document your install proceedures, so that you can go back and check the order in which things are loaded. I believe that the process is more dependent upon the order in which things are loaded than the instructions would have you believe. At least, it helped me.
What I did was, from a clean install of ubuntu 18.04, I made sure that everything WRT Vitis AI that I git cloned or installed was done without running sudo (root). In my original install, which failed, there must have been something in the install directory that required me to do a sudo. Once that happens, I think that "it's over".
I found that the instructions in here https://github.com/Xilinx/Vitis-AI  are a bit clearer than those in UG1414.
cd Vitis-AI
Yes, docker must be running, which you can verify with "docker run hello-world". And, you must be able to run it as a user other than root.
I think that
newgrp docker
Can be used to start it up in a terminal shell where it is not running.
Also, you have to download the proper docker shell. I did find the xilinx docker shells here https://hub.docker.com/u/xilinx  and there are two of them listed. When doing a "docker pull" I find that it helps to do a "docker pull -a" (for all) or the shell might not be found.
There is a very subtle error that I found in the pdf documentation in UG1414.
./docker_run.sh xilinx/vitis-ai:runtime:1.0.0-cpu
The above has an error. After the "runtime" there is a ":" and this should be a "-".
Should be
I then was able to go into samples and do
sh -x build.sh
There is some good information "hidden" here https://github.com/Xilinx/Vitis-AI/tree/master/Vitis-AI-Library where setting up the target is described a bit clearer. I have not done that yet but will soon.
I hope that this helps.
Tom
YilinChen
Hi, my friend
I found a problem happened when I run "bash -x build.sh" for the demo of yolov3, the screenshot is just like this:
I think my docker is ok because I can run it without sudo
The steps I followed for running the demo of yolov3 is based on ug1354 and my hardware is U50 board card
is there has anyone who can provide some suggestions for this problem, thanks a lot
YilinChen
Hi, Jheaton
Could you help me to take a look about the problem I mentioned above, that problem hanged over me for a long time, thanks a lot!
