vignesh99
How to install and run Vitis AI on alveo using Nimbix
I want to run the examples given on this Github repository : https://github.com/Xilinx/Vitis-AI
However, I dont find a tutorial on how to setup the environment to execute these examples.
I cloned the Vitis Ai repo on nimbix linux terminal
And went Vitis-AI/alveo/examples/vitis_ai_alveo_samples/adas_detection
I cannot perform $make. It given build error. And hence i cannot run
$source run.sh
 Is there any there installation that i need to perform to run these examples on alveo card in nimbix?
Check if the OS you are using is supported and you have all is needed installed. "nimbix linux terminal" is not an OS description. Nimbix, afaik, is a provider of cloud computing services, right? check with them what linux do they provide.
"thousands on expensive FPGAs, fast cloud services, cutting-edge AI things then someone is lost when a click produces an error"
The above could be the resume of the technology state of the art in the 21st century.
vignesh99
Thank you for your reply!
Yes, Nimbix is a cloud-based platform. They provide ready to use an instance with XILINX MLSUITE.
However, I wanted to try with VitisAI.
My task is to study and run a simulation of YOLO on an FPGA
