vignesh99
How to transfer files via serial port in Xilinx ZCU102
I am using Xilinx ZCU102 UltraScale+ FPGA board.
I am trying to run AI Vision Example algorithms given by Xilinx AI SDK
I am following this tutorial pdf https://www.xilinx.com/support/documentation/user_guides/ug1354-xilinx-ai-sdk.pdf
I can now connect to the FPGA via the serial port using Putty. I have installed the image file for ZCU102 from website and have successfully booted via sd card. I can connect to the board via serial port in putty which gives me "root@zcu102:~/Desktop"
I want to copy a file from my pc to the board and extract it in order to use the AI sdk examples
**TEXT FROM DOCUMENT**
Step 2: Installing AI Model Package
1. Enter the platform directory, then copy the xilinx_ai_model_ZCU102_2019.1-r1.deb to the
board via scp.
$cd ~/xilinx_ai_sdk_v2.0.x/ZCU102
$scp xilinx_ai_model_ZCU102_2019.1-r1.deb root@IP_OF_BOARD:~/
Note that the deb package can be taken as normal archive, and users can extract the contents on the host
side if users only need part of the models. The operation command is shown below.
$mkdir extract
$dpkg -X xilinx_ai_model_ZCU102_2019.1-r1.deb extract
2. Log in the board (via ssh or serial port), install the model package, and execute below:
#dpkg -i xilinx_ai_model_ZCU102_2019.1-r1.deb
Note the following after the installation is complete.
• Model files are stored in /usr/lib on the target side.
Step 3: Installing AI SDK Package
1. Enter the following directory, then copy the xilinx_ai_sdk_2019.1-r1.deb to the board via scp
$scp xilinx_ai_sdk_2019.1-r1.deb root@IP_OF_BOARD:~/
host side if users only need part of the libraries. Only model libraries can be separated dependently,
others are common libraries. The operation command is shown below.
$mkdir extract
$dpkg -X xilinx_ai_sdk_2019.1-r1.deb extract
2. Log in the board (via ssh or serial port), install the Xilinx AI
**END OF TEXT FROM DOCUMENT***
I got stuck now, I cannot copy the file from my pc to the board.
When I try to execute the command given above it gives me error "ssh_init: Name or service not known"
Kindly help me. How to copy files from pc to the FPGA board via serial port?
quentonh
@vignesh99
Hopefully this will give you a better starting point.
[1] Boot the board, connect to the board via USB UART, 119,200 N81.  There are four COM ports, I generally open all of them, but I believe it is the first or second in the sequence of four that is relevant.
[2] Via the UART terminal, configure the IP address of the board such that it is on a subnet which is common to the Ethernet port on your laptop (I typically set the board using this command:  "ifconfig eth0 192.168.0.254").  If you want to double-check the setting, simply run "ifconfig".  This network address is not related to the network (and subnet) of my WiFi connection.
[3] In Windows, configure your wired ethernet IP address such that it is on the same subnet (192.168.0.1).  Set the subnet mask to 255.255.255.0.  Remove the gateway setting.  Windows will AND the subnet mask with the IP address of the board with the net result that only IP packets which have a destination address of 192.168.0.x will be passed on to PuTTY.
[4] Ping back and forth to ensure connectivity between the board and the laptop.  From the laptop, ping 192.168.0.254.  Via the UART terminal, ping the laptop from the board "ping 192.168.0.1".
[5] From the windows command prompt, you should be able to use the PuTTY pscp command to copy the files to the board.  For instance "pscp file.tar.gz root@192.168.0.254:/home".
Based on my recollection, this is all that should be required.
BTW, I wouldn't recommend extracting the tar.gz files on Windows as I recall that there may be some softlink issues that arise.  I generally use a Windows laptop to connect to my board and remote in to my Linux machine to run DNNDK.  Thus, what I do is pscp the ENTIRE tar.gz archives for both DNNDK and the AI SDK to the board and then use "tar -xzvf" to extract the entire archive on the board.  From there, I leverage the instructions found in the documentation to install the necessary board files.
Also, make sure that after imaging the SD card that you boot the board fully from this fresh card (boot to the command prompt) and then reboot the board before attempting to copy the files.  Note that the Ethernet IP address will be reset on the board each time you power cycle.
Hope this helps!
--Quenton
quentonh
@vignesh99
You should connect the board to your PC via Ethernet and set the PC and board to different IP addresses on the same subnet.  For instance, set the PC to 192.168.0.1 and the ZCU102 to 192.168.0.254 (ifconfig eth0 192.168.0.254).  From there you should be able to use either the PuTTY "pscp" command from the Windows command line, or scp under Linux to copy the files to the board.  You want to copy the files over Ethernet, not over the serial port.
Don't use the UART terminal for ssh/scp, simply use the terminal (TeraTerm / Minicom) to configure the Ethernet IP address of the board.
Does this help?
--Quenton
vignesh99
@quentonh
Hi When i try to connect the board via ethernet it shows me "Net error: Connection refused"
I then manually changed the ip address of the ethernet in control panel->ethernet->properties->Internet Protocol Version 4(TCP/IPv4)
Now my ipconfig output looks like this
___
C:\Users\VigneshVS>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter Local Area Connection* 1:
Wireless LAN adapter Local Area Connection* 3:
Ethernet adapter Ethernet 3:
Link-local IPv6 Address . . . . . : fe80::813f:f928:8ff9:c6fb%17
IPv4 Address. . . . . . . . . . . : 10.201.86.1
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Default Gateway . . . . . . . . . : 10.201.0.1
Wireless LAN adapter Wi-Fi:
Link-local IPv6 Address . . . . . : fe80::a944:ab:8eb1:89e2%19
IPv4 Address. . . . . . . . . . . : 10.201.86.252
Subnet Mask . . . . . . . . . . . : 255.255.128.0
Ethernet adapter Bluetooth Network Connection:
___
The subnet Mask is automatically created, I didnt change anything.
When I try this new IP address in putty it gives me the same error
How to connect to the ssh, I tried many online resources but I didnt find an answer, thats why I chose serial port previously.
Kindly guide me on HOW TO CONNECT TO SSH.
I am using Public Wifi at my university, And LAN to USB adaptor to connect to my laptop.
Thank you.
Eagerly waiting for your reply.
quentonh
@vignesh99
Hope this helps!
--Quenton
vignesh99
I did the same as you stated in my linux pc
It gives me timeout error when i try to use pscp command and also ping.
Why does it give timeout error?
Kindly help
vignesh99
When i try to ping from putty terminal, it gives the following error:
Ping destination host unreachable
vignesh99
I initially forgot to do ifconfig in my linux terminal.  Now I did and successfully got connected to the board via ssh
However When I try to dpkg the transferred file.deb, it gives me some version error
I will try to boot my board via petalinux boot image. Hopefully that would solve the issue I guess.
Thank you Once again
smilec6h6
Thank you very much for your answer, the perfect solution to my problem!
