shixiaoke
I need network deployment file
I want to deploy the models(https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/AI-Model-Zoo) on Ultra96v2, but I don't have the corresponding deployment file(main.cc and utils.h).
I want to use these models: cf_yolov3_bdd_288_512_53.7G, dk_yolov3_cityscapes_256_512_5.46G, dk_yolov3_voc_416_416_65.42G,tf_mobilenetv1_imagenet_224_224_1.14G, tf_mobilenetv2_imagenet_224_224_1.17G,tf_ssd_voc_300_300_64.81G, tf_yolov3_voc_416_416_65.63G.
Could you give me the corresponding deployment files(main.cc and utils.h).
jasonwu
Hi @shixiaoke ,
There is a plan to deliver the calibration/deployment example codes for those models for a later version. But for the release of DNNDK 3.1 as I know it is no.
You may have a shot at Xilinx sales contact incase you may get more detailed information there.
Otherwise I would suggest you to refer to other repositories of https://github.com/Xilinx/Edge-AI-Platform-Tutorials
There are some other interesting design you can refer to and most of them have more detailed example codes.
Best Regards,
Jason
