jack_bonnell
Implementing Vitis-AI 1.2 on VCS-1
I have looked at the page to run the DNNDK tutorials and all i can see is the ability to run the DNNDK on https://github.com/Xilinx/Vitis-AI/blob/master/DPU-TRD/prj/Vitis/README.md#521-build-the-hardware-design is there any more guides etc so i can set up the DNNDK on our VCS1 board or maybe an ultra96v2?
All the Best,
Jack
jasonwu
Hi @jack_bonnell ,
Currently I am working on that. Please check the webpage here:
https://github.com/gewuek/vitis_ai_custom_platform_v1.2_tmp
Please feel free to let me know if you find any typo or information missing.
The platform creation part should work. I need to do some modification on compile kernel ELF, should be finished soon.
I am afraid that the original 2019.2+VAI1.1 version tutorial is under internal review so that I need to keep the whole repository unmodified. Would be moved  back to https://github.com/gewuek/vitis_ai_custom_platform_flow after the internal review.
Best Regards,
Jason
jack_bonnell
Thanks you! i will do!
All the best,
Jack
