lucc2
Is there any tutorial/example showing how to use concurrently 2 neural network on the same DPU
Is there any tutorial/example showing how to use concurrently 2 neural networks on the same DPU
This would definitely be using different:
A- Weights,
B- Different number of classes
It may or may not have different configuration:
1- input image sizes
2- number of layers
3- Other network specific configurations
Mainly looking at yoloV3 and/or yoloV3-tiny Darknet/Caffe models
jasonwu
Hi @lucc2 ,
You can run different network on the same DPU core, not parallel.
I was tolde that it can work if you include 2 DPU ELFs when compiling and call them by name in ARM deply code.
Best Regards,
Jason
