herogian
Kernel panic with desktop buster image
I am trying to test some neural networks with the dnndk framework.
I started with stretch + dnndk 2.08 on ZCU102 and works well, and now I would like to test dnndk 3.0 with the buster image.
The problem is that after turning on the board I get a kernel panic:
[    3.619514]  (driver?)
[    3.626034] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,)
[    3.634286] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.3 #1
[    3.641496] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[    3.646444] Call trace:
[    3.648883] [<ffffff8008088c58>] dump_backtrace+0x0/0x368
[    3.654267] [<ffffff8008088fd4>] show_stack+0x14/0x20
[    3.659304] [<ffffff8008a407f8>] dump_stack+0x9c/0xbc
[    3.664346] [<ffffff800809bdc0>] panic+0x11c/0x274
[    3.669128] [<ffffff8008d91124>] mount_block_root+0x1a8/0x27c
[    3.674855] [<ffffff8008d91430>] mount_root+0x11c/0x134
[    3.680063] [<ffffff8008d915b4>] prepare_namespace+0x16c/0x1b4
[    3.685879] [<ffffff8008d90d44>] kernel_init_freeable+0x1b8/0x1d8
[    3.691955] [<ffffff8008a52b48>] kernel_init+0x10/0x100
[    3.697163] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    3.702458] SMP: stopping secondary CPUs
[    3.706364] Kernel Offset: disabled
[    3.709835] CPU features: 0x002004
[    3.713219] Memory Limit: none
[    3.716261] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown)
someone can help me?
thanks
