vaibhav810
LSTM support by DNNDK + DPU for EDGE INFERENCE
My model has CNN + LSTM branch. Is it possible to process LSTM tensor on ARM core/CPU if its not supported by IP
Vaibhav Kothari
Owner
Edge.AI
Tags (5)
rbriegel
Hi, I did use Tensorflow Lite to run the LSTM Branch on the ARM while cnn inference was done by the DPU.
rbriegel
vaibhav810
Thanks for the reply.
Hiw do you sync both branch during inference on post prosesing side? Can you share model deails?
