dvukadin
Low accuracy with custom FCN model after compiling in tensorflow2 Vitis AI 1.3
I have quantized and finetuned my custom FCN model in TF 2 and accuracy was very good after finetuning.
But, when I compile with vai_c_tensorflow2 and run on ZCU104 common image from Xilinx (petalinux 2020.2), accuracy is very low.
Here is model summary:
Model: "functional_1"
_________________________________________________________________
Layer (type)                 Output Shape              Param #
input_1 (InputLayer)         [(None, 128, 128, 3)]     0
block1_conv1 (Conv2D)        (None, 128, 128, 64)      1792
block1_conv2 (Conv2D)        (None, 128, 128, 64)      36928
block1_pool (MaxPooling2D)   (None, 64, 64, 64)        0
block2_conv1 (Conv2D)        (None, 64, 64, 128)       73856
block2_conv2 (Conv2D)        (None, 64, 64, 128)       147584
block2_pool (MaxPooling2D)   (None, 32, 32, 128)       0
bottleneck_1 (Conv2D)        (None, 32, 32, 160)       20971680
bottleneck_2 (Conv2D)        (None, 32, 32, 160)       25760
upsample_2 (Conv2DTranspose) (None, 128, 128, 20)      51200
reshape (Reshape)            (None, 327680, 1)         0
Here is output message after compiling:
 I use vitis::ai::DpuTask for running model.
model = vitis::ai::DpuTask::create(kernelPath);
model->setMeanScaleBGR(meanValues, scaleValues);
model->setImageBGR(preprocessedImage);
m_model->run(0);
outputTensor = m_model->getOutputTensor(0);
For converting fixpoint to float, I use this function:
std::vector<float> convert_fixpoint_to_float(const vitis::ai::library::OutputTensor &tensor) {
auto scale = vitis::ai::library::tensor_scale(tensor);
auto data = (signed char *)tensor.get_data(0);
auto size = tensor.width * tensor.height * tensor.channel;
auto ret = std::vector<float>(size);
transform(data, data + size, ret.begin(),
[scale](signed char v) { return ((float)v) * scale; });
return ret;
What could be wrong, why accuracy is very good before compiling and very low on ZCU104?
yz87@rice.edu
I had the similar issue of drastically dropped accuracy after compiling in tensorflow2.....
