PETALINUX DPU TRD on ZCU104 ERROR
My VIVADO is 2019.1, petalinux is 2019.1. I build the HDF from https://forums.xilinx.com/t5/Machine-Learning/DPU-TRD-for-ZCU104/td-p/958695. But when I build in petalinux , some error happens.
| xfsbl_board.c: In function 'XFsbl_BoardConfig':
| xfsbl_board.c:587:35: error: 'XPAR_XIICPS_0_DEVICE_ID' undeclared (first use in this function); did you mean 'XPAR_XTTCPS_0_DEVICE_ID'?
|   I2c0CfgPtr = XIicPs_LookupConfig(XPAR_XIICPS_0_DEVICE_ID);
| xfsbl_board.c:587:35: note: each undeclared identifier is reported only once for each function it appears in
| make: *** [Makefile:34: xfsbl_board.o] Error 1
