litaoqiyanjie
PetaLinux Installation Incompatble Error!!
I try ot install PetaLinux to ZCU104 according to the guide https://www.xilinx.com/support/documentation/user_guides/ug1354-xilinx-ai-sdk.pdf.
Hower, it shows that "Error: Incompatible SDK installer! Your host is aarch64 and this SDK was built for x86_64 hosts".
Is there SDK for aarch64 for downloading?
Your problem is that you are trying to install the Petalinux SDK on the ZCU104 board. This is incorrect.
The Petalinux SDK is intended to be installed on your host system, a computer or VM running Ubuntu 16.04 (or 14.04). This is part of the setup of the Cross-Compiling Environment, Chapter 4 in UG1354 (Xilinx AI SDK User Guide).
litaoqiyanjie
Thanks for your help.
It works for me!!!
Best regards,
