Problem with xilinx-u250-xdma-201820
Hi all,
I have had a problem running Image_classification_tensorflow on Alveo u250.
When I use xilinx-u250-201830 from the OS side all the xbutil validate and query runs successfully but when I run image_classification_tensorflow I get Runtime Error: could not init FPGA: xclbin.
I followed this link:
https://forums.xilinx.com/t5/Xilinx-ML-Suite/RuntimeError-Could-not-init-FPGA-upon-runing-image/td-p/1016294
mentioning that the "overlaybins provided by xilinx ml-suite supports only 2018.2 xrt and xdma environment". I followed this link:
https://www.xilinx.com/products/acceleration-solutions/xilinx-machine-learning-suite.html#gettingStartedU250
and installed xilinx-u250-xdma-201820. When I tried to flash the card, it says the DSA version is not applicable and the xbutil validate and query returns the following:
xbutil validate
INFO: Found 1 cards
ERROR: Failed to open device: 0000:03:00.0
ERROR: Can't open card[0]
ERROR: Some cards failed to validate.
xbutil query
INFO: Found total 1 card(s), 0 are usable
ERROR: Card [0] is not ready
Any help would be sincerely appreciated
Re: Problem with xilinx-u250-xdma-201820
Hi @sshams2
Can you give you os details?
V Durga
Thanks for your response.
Here is the os information
lsb_release -a
LSB Version: :core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
Distributor ID: CentOS
Description: CentOS Linux release 7.5.1804 (Core)
Release: 7.5.1804
Codename: Core
