Profiling DPU application
i am trying to profile a DPU-based application on the ZCU102. I have used the DPU profiler to look at the operations performed within the IP itself.
As a next step, i'm willing to look into data that is flowing between DRAM-CPU and also into call-stacks on the CPU side.
I know there exist the Vitis Profiler / Vitis Analyzer to look into HLS Kernel accelerators. Can those tools be used with DPU-based acceleration too?
If not, is there something like this available for the case i'm describing?
The Vitis AI Profiler can help profiling and visualizing AI applications. It will be available in the upcoming Vitis AI 1.2.
When will Vitis AI 1.2 be released?
