erwann_kervennic
Pure FPGA and Vitis AI
I'm currently using Vitis AI with a ZCU104. It works, but I would like to know if it's possible to use Vitis AI to deploy AI on KCU105 using a MicroBlaze architecture. I know that Vitis AI development flow uses .json file to compile networks depending on the target. Is it planned to release a .json file for the KCU105? Or what shoud I do in order to perform the network compilation for the KCU105?
Thank you,
Erwann
jasonwu
Hi @erwann_kervennic ,
I am afraid that as I know we can't run Vitis AI stacks on microblaze.
The DPU IP can only support MPSoC/Zynq devices. And counted on the VAI lib package release. Now we can only run Vitis AI on MPSoC devices.
Best Regards,
Jason
billhunter
Except that Xilinx is claiming to be able to run Vitis AI on the microblaze for their new Kintex space part, "bringing AI to space".
