sitting
Resnet 50 with custom datasets
We have custom datasets and want to use xilinx resnet50 directly, is it possible?
If not, do we need to train new resnet50 model with our custom datasets? Is there any tutorial?
Sitting
zhijiexu
Hi, @sitting
You also can use other framework like pytorch and tensorflow, but different framework have different API it supported.
And you can train it in your own environment ,and quantified, compile in the docker environment
Best regard,
Zhijie
zhijiexu
hi, @sitting
Yes, you need to train new resnet50 model with your custom Datasets.
The related Tutorial you can refer to was showed below:
https://github.com/Xilinx/Vitis-Tutorials/blob/master/Machine_Learning/Design_Tutorials/04-Keras_GoogleNet_ResNet/README.md
Also, you can read ug1414 and pg338,
Best regard,
Zhijie
Don't forget to reply, give kudos and accept as a solution!
sitting
Hi @zhijiexu ,
I need to prepare the origin resent50 model and use caffe-xilinx to train it?
Sitting
Sitting
zhijiexu
Hi, @sitting
Best regard,
Zhijie
