anz162112
Resnet50+ssd error using Deephi
I am trying to quantise and run resnet50+ssd on ZCU102 using Deephi.
Following the steps in the tutorial,
https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/ML-SSD-PASCAL
I could retrain  the model. The tool showed no error when used Decent to quantise the model. But when I used DNNC to create .elf files, following error is shown.
[DNNC][Error] Failed to find available backend optimization pattern for current layer [relu_stage1_block3_bn].
I cant understand this error. Any help on this would be appreciated.
Shikha
Shikha Goel
(Ph.D. , IIT Delhi)
