ahmadzoubi
Runtime Error running DPUCAHX8L on Alveo u280
I am trying to run the example https://github.com/Xilinx/Vitis-Tutorials/tree/master/Machine_Learning/Design_Tutorials/03-using_densenetx on the alveo u280 using the Vitis ai 1.3 environment provided by Nimbix.
The example runs smoothly when i compile to the DPUCAHX8H, However when i try to compile for the dpu optimized for latency DPUCAHXL i always get this error:
File "app_mt.py", Line 75 , in <list_comp>
if cs.has_attr("device") and cs.get_attr("device").upper() == "DPU
RuntimeError: bad any_cast
am not sure what's the problem here?
linhtq08
it is likely you already solved this, but I put it here anyway in case someone else need it.
When running app, you need to use the python3 binary in /usr/bin/python3, not the one in conda environment path:
When working with Vitis AI, I find it much less frustrated when follow EXACTLY what the guide said...
shjang
I faced same error.
How can I fix it?
ahmadzoubi
i honestly don't know, it does compile but the runtime always throw that exception.
Hope someone have an answer for us, as far as i know the vitis ai 1.3 has the support for this DPU
linhtq08
