rubenlesmes
TensorFlow 2.0 model inference not working as expected
I am trying to do inference with a compiled mnist model. The model has been built with Keras Functional API and with the permitted layers.
inputs = tf.keras.Input(shape=(28, 28, 1))
x = tf.keras.layers.Conv2D(32, (3, 3), activation='relu')(inputs)
x = tf.keras.layers.MaxPooling2D((2,2))(x)
x = tf.keras.layers.Conv2D(16, (3, 3), activation='relu')(x)
x = tf.keras.layers.Flatten()(x)
x = tf.keras.layers.Dense(128, activation='relu')(x)
x = tf.keras.layers.Dense(64, activation='relu')(x)
outputs = tf.keras.layers.Dense(10, activation='softmax')(x)
mnist = tf.keras.Model(inputs=inputs, outputs=outputs)
I have done inference with the pre-compiled models (float and quantized) and they seem to do well, but after compilation with vai_c_tensorflow2 the dpu inference seems to load null weights.
dpu = overlay.runner
inputTensors = dpu.get_input_tensors()
outputTensors = dpu.get_output_tensors()
shapeIn = tuple(inputTensors[0].dims)
shapeOut = tuple(outputTensors[0].dims)
outputSize = int(outputTensors[0].get_data_size() / shapeIn[0])
output_data = [np.empty(shapeOut, dtype=np.float32, order="C")]
input_data = [np.empty(shapeIn, dtype=np.float32, order="C")]
image = input_data[0]
image[0,...] = test_data[0]
job_id = dpu.execute_async(input_data, output_data)
dpu.wait(job_id)
 Output data looks like this:
[array([[0., 0., 0., 0., 0., 0., 0., 0., 0., 0.]], dtype=float32)]
Is there any other processing or known bugs about Tensorflow 2 models compilation?
Any ideas would be appreciated.
chaoz
Hi @rubenlesmes
I don't  see any relate bugs in Tensorflow 2 models compilation,
Actually I have made a similar design before, could you try with the same steps and files and see is there any difference?
https://github.com/lobster1989/Mnist-classification-Vitis-AI-1.3-TensorFlow2
Chao
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
Chao
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
rubenlesmes
Same problem with your design, I had to recode the compiler to the card I'm using, a Xilinx Zynq UltraScale+ MPSoC Ultra96-V2.
I believe that the issue could be the architecture file arch.json as the one I'm using is the one on DPU-PYNQ repository.
Is there any other arch.json file I could test for the platform I am currently using?
chaoz
arch.json come from your DPU configuration. Is the arch.json consistent with your hardware design?
By the way, are you running the xmodel file on board and getting the output?
Chao
Chao
rubenlesmes
I have not gone into hardware designing and there's no default arch.json in my UltraScale+ card, I'm using the one provided by the DPU-PYNQ repository. Is there any way to make sure It is consistent with my hardware?
Yes, I'm running the xmodel file on board and getting null outputs, there's a preview of the printed output in the first post.
chaoz
Normal we first make a Vivado hardware platform design, then we intergrated DPU in to hardware design accordding to DPU-TRD and then a arch.json file is generated for the paritcular DPU configuration.
But in case the DPU configuration is not consistent, you would get an error in the first place when running model on board.
By the way, how did you integrate DPU into hardware design? Or you just used a released platform design?
Reference of DPU-TRD,
https://github.com/Xilinx/Vitis-AI/tree/master/dsa/DPU-TRD
Chao
Chao
rubenlesmes
I was just trying to avoid making a Vivado hardware platform design, If that's possible, as It's not within my scope of research. So I was trying with arch.json files found in DPU-PYNQ repository or with the following configurations, which are the ones associated with DPUCZDX8G_ISA0_B1600_MIN and DPUCZDX8G_ISA0_B1600_MAX.
{"fingerprint":"0x1000020f2014404"}
{"fingerprint":"0x100002022010104"}
I have not gotten any errors while loading the xmodel into the platform.
chaoz
What is your targeted board?
Did you use a prebuilt platform for the board?
Chao
Chao
rubenlesmes
My targeted board is an Avnet Zynq UltraScale+ MPSoC Ultra96-V2.
I am not sure what you mean by prebuilt platform, If that's the image burned into the SD card then yes, It's the build ultra96v2_oob_2020_1_210303_8GB.zip found on the Avnet starter guide.
chaoz
Ok.
So I guess ultra96v2_oob_2020_1_210303_8GB.zip should have the same DPU intergrated in it's platform, otherwise I think error will be thrown.
Could you please attach the full log of running application on board? Have you done any custom to app_mt.py?
Chao
Chao
rubenlesmes
I have attached the entire log of the notebook running the inference on board. During the creation of the xmodel I did not edit the app_mt.py file.
