[URGENT] DPU B4096 Resources Utilization and Power Reports for ZCU 104
I am using this DPU image that runs on the ZCU104 board.
Image URL: https://www.xilinx.com/bin/public/openDownload?filename=xilinx-zcu104-dpu-v2020.1-v1.2.0.img.gz
The DPU cores implemented in this image have the specifications shown in the below image:
DPU Properties on ZCU 104 ImageDPU Properties on ZCU 104 Image
 When I try to synthesize the DPU TRD applying these specifications, I end up having that the required resources exceed the resources available on the FPGA. I use Vivado 2020.1, and I follow the same steps demonstrated in the Userguide. I tried different synthesis strategies.. Same result.
I just need someone to help me with either the complete resources utilization and power reports or to solve this issue I am facing to smoothly and successfully generate these reports myself!
Thanks!
You should enable the URAM option.
Thank you, @microdent. That worked like magic!
