siliangz
Vitis AI 1.3 API
I am very new to VART APIs of Vitis AI 1.3. I am trying to use it in my application.
I saw VART provides C++ APIs and Python APIs. But because of some limitations that I can't use either of them.
But I found <vart.h> and <xir.h> in the library. It seems like they provide a C-style interface.
And I am able to use them to create the runner and get the input/output tensors.
But I have some issues getting the tensor buffer.
in the example application which uses C++ APIs. It uses Class CpuFlatTensorBuffer to create the tensor buffer.(like below)
/* in/out tensor refactory for batch inout/output */
    batchTensors.push_back(std::shared_ptr<xir::Tensor>(xir::Tensor::create(
        inputTensors[0]->get_name(), in_dims,
        xir::DataType{xir::DataType::FLOAT, sizeof(float) * 8u})));
    inputs.push_back(std::make_unique<CpuFlatTensorBuffer>(
        imageInputs, batchTensors.back().get()));
        outputTensors[0]->get_name(), out_dims,
    outputs.push_back(std::make_unique<CpuFlatTensorBuffer>(
        FCResult, batchTensors.back().get()));
 But <vart.h> and <xir.h> don't provide the way to create tensor buffer.
I am wondering if <vart.h> and <xir.h> are good to use?
Does VART have C-style APIs?
chaoz
@siliangz I got confirmation that the C implementation of DPU runner should not be used directly.
Chao
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
chaoz
Hi @siliangz
There are only C++/Python APIs. Don't think there is C-style APIs for users.
siliangz
 Hi Chaoz,
I found this file in the repo.
And this test file as well.
Is that a valid API to use? According to the test file, it seems valid.
chaoz
@siliangz
Per my understanding that c implementation of DPU runner is for python ctypes.
Offically we only have C++ and python API.
For your concern, I will double check and get back.
Chao
siliangz
@chaoz
Thank you so much for your help.
chaoz
Chao
siliangz
@chaoz Thank you so much for your reply.
