Vitis AI Segmentation Fault during Calibration
I'm trying to calibrate a YoloV3 with custom weights and an increased input size. The calibration images get loaded correctly and after some time calibration finishes (with 'INFO: Calibration Done' printed in the terminal). Immediately after this message, a segmentation fault occurs without any further information. At this point, the vai_q_output directory only contains a temp folder with a couple of files in it.
Does someone have any idea about this?
Best
Martin
Re: Vitis AI Segmentation Fault during Calibration
Are you using the gpu or cpu version of the quantizer?
Can you share the terminal output during calibration.
I'm running the vitis-ai:tools-1.0.0-gpu container.
The terminal output is as follows:
INFO: Calibrating for 50 iterations...
100% (50 of 50) |#######################################################################################################################################| Elapsed Time: 0:12:26 Time:  0:12:26
INFO: Calibration Done.
Segmentation fault (core dumped)
Are you ruinning the in the Caffe or TF conda env?
Usually when I see seg faults in calibration its an issue reading the images.
Did you see any other warnings?
I'm using the tf env (my YoloV3 model is a converted darknet model).
I previously had an error where an image could not be loaded but I resolved it (the image had a wrong format). Now all images are just jpegs and I don't see any other warnings or errors anymore. The tf model check before also finishes successfully.
Can I enable some debug flags to get additional information?
Whats your input function look like. Is the image resolution getting set properly there?
my input function is based on the examples:
def letterbox_image(image, size):
    '''resize image with unchanged aspect ratio using padding'''
    # OpenCV image shape is height, width, channels!
    ih, iw, _ = image.shape
    w, h = size
    scale = min(w/iw, h/ih)
    nw = int(iw*scale)
    nh = int(ih*scale)
    image = cv2.resize(image,(nw,nh))
    new_image = np.ones([h, w, 3], dtype=np.uint8) * 128
    #new_image = Image.new('RGB', size, (128,128,128))
    #new_image.paste(image, ((w-nw)//2, (h-nh)//2))
    loc_w = (w-nw)//2
    loc_h = (h-nh)//2
    new_image[loc_h:loc_h+nh, loc_w:loc_w+nw] = image
    return new_image
def preprocessing_fn(image, model_image_size=(416,416)):
    if model_image_size != (None, None):
        assert model_image_size[0]%32 == 0, 'Multiples of 32 required'
        assert model_image_size[1]%32 == 0, 'Multiples of 32 required'
        boxed_image = letterbox_image(image, tuple(reversed(model_image_size)))
    else:
        new_image_size = (image.width - (image.width % 32), image.height - (image.height % 32))
        boxed_image = letterbox_image(image, new_image_size)
    image_data = np.array(boxed_image, dtype='float32')
    image_data /= 255.
    return image_data
calib_image_dir = "images/"
calib_image_list = "images/tf_calib.txt"
calib_batch_size = 10
def calib_input(iter):
    images = []
    line = open(calib_image_list).readlines()
    for index in range(0, calib_batch_size):
        curline = line[iter * calib_batch_size + index]
        calib_image_name = curline.strip()
        #print('Loading image {}'.format(calib_image_name))
        image = cv2.imread(calib_image_dir + calib_image_name)
        image = preprocessing_fn(image, model_image_size=(512,512))
        images.append(image)
    return {"inputs": images}
So the image size is 512x512 which matches my yoloV3 model (netron screenshot of the input section below)
