Vitis-Ai Opencv Library function cv::imshow() ERROR
I am learning Vitis AI and Alveo U200 recently. After I conda activate  vitis-ai-caffe in docker, neither cv.imshow() in python nor cv::imshow() in C++ works .  But I want to use the function to visulize images, how to FIX this!
logs:
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
cv2.error: OpenCV(3.4.2) /tmp/build/80754af9/opencv-suite_1535558553474/work/modules/highgui/src/window.cpp:632: error: (-2:Unspecified error) The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function 'cvShowImage'
Hi @VitisAiFPGA ,
Not sure if I understand your question.
In the design you mentioned OpenCV should be used a third party library.
In Python if OpenCV command can't work I would suggest you to check the library list use "pip list" and install the library use "pip install" if necessary.
Best Regards,
Jason
