Vitis installation
Can Vitis be installed on ubuntu 20.04 LTS?
graces
The supported OS is as follows for Vitis 2020.1:
https://www.xilinx.com/html_docs/xilinx2020_1/vitis_doc/aqm1532064088764.html
There's large chance that you get it running on 20.04. However, it's not guaranteed to work as it's not fully tested.
