What is the default ip address,username and password of zedboard-dnndkv3.1-image
I have download zedboard-dnndkv3.1-image and flash it into my zedboard, and now I want to connect it via ssh. However , I didn't find the ip address ,username and password in the document .
Can anyone help me with it?
rbriegel
I can only speak from my experience with the ZCU104 Board but in my case the IP was not fix, so I had to check connected clients on my router. pw and username was root.
Hope this helps!
Thanks a lot, that  helps me a lot to some extent. Finally I use arp -a command to discover the new ip entry ,and that is the ip address of my zedboard.
