Xilinx_ai_sdk 2.0.5 open(/dev/dpcma) failed
 I used a petalinux to build a custom design from zcu102 bsp (zcu102-dpu-trd-2019-1-190809.zip). I want to use xilinx_ai_sdk for my program. But when I run the program, it shows open(/dev/dpcma) failed. I'm wondering how to solve this problem.
Is this not helpful?
You can try install the dpcma.ko manually on your target side.
https://forums.xilinx.com/t5/Deephi-DNNDK/AI-SDK-can-t-run-sample-because-dnndk-version-is-3-0/m-p/1022788
I got the following error when try to insert dpcma.ko
root@zcu102-dpu-trd-2019:~# insmod dpcma.ko
insmod: can't insert 'dpcma.ko': invalid module format
My concern is the kernel image on board is 4.19.0+ while the dpcma.ko provided is in 4.19.
I was able to execute the insmod command successfully.
root@ultra96:/media/card/xilinx_ai_sdk/samples/classification# lsmod
Tainted: G
dpcma 16384 0 - Live 0xffffff8000d49000 (O)
dpu 45056 0 - Live 0xffffff8000d38000 (O)
mali 303104 0 - Live 0xffffff8000cd8000 (O)
uio_pdrv_genirq 16384 0 - Live 0xffffff8000cb0000
root@ultra96:/media/card/xilinx_ai_sdk/samples/classification# uname -r
4.19.0-xilinx-v2019.1
I built a image with kernel 4.19.0 which is created by petalinux 2019.1 default.
Are you not using the default kernel? or Are you changing the kernel version with recipes-kernel?
I am using petalinux 2019.1 as well, while my linux kernel is 4.19.0+ shown as follows:
root@zcu102-dpu-trd-2019:/lib/modules/4.19.0-xilinx-v2019.1/extra# uname -sr
Linux 4.19.0+
I didn't modify my recipe-kernel while my .bbapend file shows
"LINUX_VERSION_EXTENSION = "+"
SRC_URI += "file://user_2019-10-09-16-32-00.cfg"
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
How can I compile my petalinux kernel with 4.19.0
An update: I modified to .bbapend file so that my LINUX_KERNEL_EXTENSION=-xilinx-v2019,1. However, it gives me a different error when I insmod dpcma.ko
[ 158.013586] dpcma: Unknown symbol kmem_cache_alloc_trace (err -2)
[ 158.019695] dpcma: Unknown symbol _mcount (err -2)
insmod: can't insert 'dpcma.ko': unknown symbol in module, or unknown parameter
You try to enable kernel traces function.
In Petalinux2019.1
petalinux-config  -c kernel
Kernel hacking -> Tracers
-> Kernel Function Tracer
-> Kernel Function Graph Tracer
-> Scheduling Latency Tracer
I think your insmod error will be disappeared.
However , I can't execute AI SDK example..
F1011 07:55:57.536851 2618 buffer_object_fd.cpp:97] Check failed: fd > 0 (-1 vs. 0) , open(/dev/dpcma) failed.
*** Check failure stack trace: ***
Aborted
It would be difficult for me if there is no original build environment.
Hi all,
Please contact your local FAE. And ask them Xilinx AI BSP for ZCU102/ZCU104/Ultra96 board images with DNNDK v3.1.
Long.
A correct approach is to compile the source code of dpcma with the correct petalinux release.
1) download the source file and the readme file from this post
2) create a BSP - you might for example follow PG388, starting from page 51:
% cd $TRD_HOME/apu/dpu_petalinux_bsp
% petalinux-create -t project -s xilinx-dpu-trd-zcu102-v2019.1.bsp
% cd zcu102-dpu-trd-2019-1
% petalinux-config ––get-hw-description=$TRD_HOME/pl/pre-built --silentconfig
3) Unzip the dpcma.tar.gz to the “recipes-xxx” directory, such as
% cp dpcma.tar.gz <BSP_Path>/project-spec/meta-user/recipes-apps
% tar xzvf dpcma.tar.gz
4) update the devicetree:
add the following information to the device-tree in $TRD_HOME/apu/dpu_petalinux_bsp/zcu102-dpu-trd-2019-1/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
   dpcma {
         compatible = "deephi,cma";
5) run a new petalinux-build
By using dpcma.tar.gz ,  I have been able to execute AI SDK model . (test_jpeg_classification_resnet_18)
By the way, I copied dpcma recipes to recipes-module folder instead of recipes-apps folder.
I copied dpcma folder to recipes-module folder,executive command:
petalinux-build -c dpcma
[INFO] building dpcma
[INFO] sourcing bitbake
[INFO] generating user layers
INFO: bitbake dpcma
Loading cache: 100% |################################################################################| Time: 0:00:00
Loaded 3816 entries from dependency cache.
Parsing recipes: 100% |##############################################################################| Time: 0:00:02
Parsing of 2781 .bb files complete (2779 cached, 2 parsed). 3816 targets, 150 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |###########################################################################| Time: 0:00:04
Checking sstate mirror object availability: 100% |###################################################| Time: 0:00:14
Sstate summary: Wanted 329 Found 102 Missed 454 Current 1794 (31% match, 89% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: dpcma-1.0-r0 do_compile: oe_runmake failed
ERROR: dpcma-1.0-r0 do_compile: Function failed: do_compile (log file is located at /home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0/temp/log.do_compile.24729)
ERROR: Logfile of failure stored in: /home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0/temp/log.do_compile.24729
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 KERNEL_src=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source KERNEL_PATH=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source KERNEL_VERSION=4.19.0+ CC=aarch64-xilinx-linux-gcc -fuse-ld=bfd -fdebug-prefix-map=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0=/usr/src/debug/dpcma/1.0-r0 -fdebug-prefix-map=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0/recipe-sysroot= -fdebug-prefix-map=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source=/usr/src/kernel LD=aarch64-xilinx-linux-ld.bfd AR=aarch64-xilinx-linux-ar O=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-build-artifacts KBUILD_EXTRA_SYMBOLS=
| make -C /home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source M=/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0
| make[1]: Entering directory '/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source'
| make[2]: Entering directory '/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-build-artifacts'
| ERROR: Kernel configuration is invalid.
| include/generated/autoconf.h or include/config/auto.conf are missing.
| Run 'make oldconfig && make prepare' on kernel src to fix it.
| make[2]: *** [/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source/Makefile:643: include/config/auto.conf] Error 1
| make[2]: Leaving directory '/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-build-artifacts'
| make[1]: *** [Makefile:146: sub-make] Error 2
| make[1]: Leaving directory '/home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work-shared/zcu104-zynqmp/kernel-source'
| make: *** [Makefile:6: all] Error 2
| ERROR: oe_runmake failed
| WARNING: /home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0/temp/run.do_compile.24729:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/yangar/work/petalinux/zcu104_102trdbsp/build/tmp/work/zcu104_zynqmp-xilinx-linux/dpcma/1.0-r0/temp/log.do_compile.24729)
ERROR: Task (/home/yangar/work/petalinux/zcu104_102trdbsp/project-spec/meta-user/recipes-modules/dpcma/dpcma.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5570 tasks of which 5569 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build dpcma
Have you ever seen this mistake before?can you tell me why? thanks!
The file seems to be missing from the message.
If you clean the environment, it may succeed, so can you try it once?
https://forums.xilinx.com/t5/Embedded-Linux/petalinux2019-1-Kernel-configuration-is-invalid/td-p/1029931
In your way, I have solved the problem,thanks!
