ZCU104 DPU LOW MEM ERROR
When I run ddump, it says"[DDump] Error : not found any DPU kernel." But I have /dev/dpu and /dev/pcma.
root@AI-V1:~/pack# ./test_jpeg_yolov3_adas_512x256  sample_yolov3_adas_512x256.jpg
WARNING: Logging before InitGoogleLogging() is written to STDERR
F1129 06:36:03.565565  2265 dpu_control_dnndk.cpp:130] Check failed: retval == 0 (-1 vs. 0) run dpu failed.
*** Check failure stack trace: ***
Aborted
root@AI-V1:~/pack# ddump  -f s2 -c
root@AI-V1:~/pack#
root@AI-V1:~/pack# ls /dev/dpu
/dev/dpu
root@AI-V1:~/pack# ls /dev/dpcma
/dev/dpcma
When I run dexplorer -w , it says:
root@AI-V1:~/pack# dexplorer -w
[DPU IP Spec]
IP  Timestamp            : 2019-11-28 10:30:00
DPU Core Count           : 2
[DPU Core Configuration List]
DPU Core                 : #0
DPU Enabled              : Yes
DPU Arch                 : B4096
DPU Target Version       : v1.4.0
DPU Freqency             : 300 MHz
Ram Usage                : Low
DepthwiseConv            : Enabled
DepthwiseConv+Relu6      : Enabled
Conv+Leakyrelu           : Enabled
Channel Augmentation     : Enabled
Average Pool             : Enabled
DPU Core                 : #1
DPU Enabled              : Yes
DPU Arch                 : B4096
Ram Usage                : Low
