liangxinyu86
camera with UPU1.4
The xilinx_dnndk_v3.0_190531 has some  example about YOLO. ,but  all  about  read  picture and  video, No  camera.  The  function is packaged .So  I  want to know how to  use camera to  do  yolov3_adas_512x256?
linqiang
Xilinx AI SDK do support the usb camera input. Try this:
./test_video_yolov3_adas_512x256 0 -t 8
0 means the first USB camera device node. If you have multiple USB camera, the value might be 1,2,3 etc.
linqiang
liangxinyu86
Thanks for your  proposal.  It can  open the camera ,but  not work well .  I  have solved this  problem  use  another  method。And  ,I think   AI_SDK  can   use  camera , but  need  consumer to  modify  the  program.
jiaoliu
Does this command have a tutorial?
jiaoliu
Hello, how did you change it? May I have a look at your code?
liangxinyu86
Sorry, I cannot  share it  for you , because  this  is  a project  of  my   company.    but,  if   you  have  problem  about , I can  help  you .
jiaoliu
It's ok,Is it based on the test-video file? I tried to change the test-image before, but it was unsuccessful.
@xx
@linqiang
@linqiang  已写:
what's the meaning of -t 8?  is there more information about how to use camera?
quentonh
-t is the number of threads, so 8 threads in this case.
