datapro
create runner
When I run following code
I don't know why there was a program error.
So how to use create_runner?
My board is U200 and I'm using Vitis AI docker pytorch image
###my code###
from ctypes import *
from typing import List
import cv2
import numpy as np
import xir
import vart
import os
import math
import threading
import time
import sys
def get_child_subgraph_dpu(graph: "Graph"):
    assert graph is not None, \
        "Input Graph object should not be None."
    root_subgraph = graph.get_root_subgraph()
    assert root_subgraph is not None, \
        "Failed to get root subgraph of input Graph object."
    if root_subgraph.is_leaf:
        return []
    child_subgraphs = root_subgraph.toposort_child_subgraph()
    assert child_subgraphs is not None and len(child_subgraphs) > 0
    return [cs
            for cs in child_subgraphs
            if cs.has_attr("device") and cs.get_attr("device").upper() == "DPU"]def main():
    # 이미지 경로 설정
    img_path = "./dataset/val/baboon.bmp"    # 스레드 수 설정
    threadnum = 1    i = 0
    g = xir.Graph.deserialize("test.xmodel")
    subgraphs = get_child_subgraph_dpu(g)
    # print(dir(vart.Runner.create_runner))
    # run = Runner("./")
    print(type(subgraphs[0]))
    r = vart.Runner.create_runner(subgraph=subgraphs[0], mode=str("run"))if __name__ == '__main__':
    main()
error
(vitis-ai-pytorch) Vitis-AI /workspace/hansol/FSRCNN > python3 abc.py
<class 'xir.Subgraph'>
Traceback (most recent call last):
  File "abc.py", line 102, in <module>
    main()
  File "abc.py", line 84, in main
TypeError: create_runner(): incompatible function arguments. The following argument types are supported:
    1. (subgraph: xir::Subgraph, mode: str = '') -> vart.RunnerInvoked with: kwargs: subgraph=<xir.Subgraph named 'subgraph_ResNet__ResNet_AdaptiveAvgPool2d_avgpool__483_i0'>, mode='run'
zhipengl
Thank you for your feedback.
Could you please share the “test.xmodel” so that we can further analyze the problem.
datapro
thanks this is my test model
datapro
Could you share with me if there's any progress? I reply again because there has been no feedback since I attached the model.
