decent pickle error
I am running decent tool, and I got following error, which seems related with pickle. But if I am testing my input function stand alone, it won't give this error message. I don't know if it's dnndk tool relaated or not. Please advise. Thanks!
QUANTIZE
Using TensorFlow backend.
INFO: Checking Float Graph...
Traceback (most recent call last):
  File "/harddisk1/xxxx/anaconda2/envs/decent/bin/decent_q", line 10, in <module>
    sys.exit(run_main())
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/site-packages/tensorflow/contrib/decent_q/python/decent_q.py", line 540, in run_main
    app.run(main=my_main, argv=[sys.argv[0]] + unparsed)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/site-packages/tensorflow/python/platform/app.py", line 125, in run
    _sys.exit(main(argv))
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/site-packages/tensorflow/contrib/decent_q/python/decent_q.py", line 539, in <lambda>
    my_main = lambda unused_args: main(unused_args, FLAGS)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/site-packages/tensorflow/contrib/decent_q/python/decent_q.py", line 335, in main
    quantize_frozen(input_graph_def, input_fn, q_config, s_config, flags.skip_check)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/site-packages/tensorflow/contrib/decent_q/python/decent_q.py", line 222, in quantize_frozen
    check_float_graph(input_graph_def, input_fn, q_config, s_config)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/site-packages/tensorflow/contrib/decent_q/python/decent_q.py", line 143, in check_float_graph
    inputs = input_fn(iter=0)
  File "./unet_input_fn.py", line 45, in calib_input
    data = pickle.load(f)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/pickle.py", line 1384, in load
    return Unpickler(file).load()
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/pickle.py", line 864, in load
    dispatch[key](self)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/pickle.py", line 1075, in load_inst
    klass = self.find_class(module, name)
  File "/harddisk1/xxxx/anaconda2/envs/decent/lib/python2.7/pickle.py", line 1132, in find_class
    klass = getattr(mod, name)
AttributeError: 'module' object has no attribute 'Data'
QUANTIZATION COMPLETED
My decent shell script:
decent_q quantize \
  --input_frozen_graph ./noise_filter_model/Unet.pb \
  --input_nodes input_1 \
  --input_shapes ?,1024,1024,6 \
  --output_nodes conv2d_23/Sigmoid \
  --method 1 \
  --input_fn some_input_fn.calib_input
The input function:
import pickle
#from parseHit import *
#from plotLayer import *
import glob
import time
import numpy as np
from scipy.ndimage import zoom
from skimage.measure import block_reduce
from scipy import sparse as sp
import keras
from keras.backend.tensorflow_backend import set_session
#from preprocess import *
from data import Data
#import tensorflow
#from tensorflow.keras.backend import set_session
width = 1024
data_shape=(width, width, 6)
batch_size = 1
in_dir = "smallDataset"
path = in_dir
cached_data = {}
file_list = glob.glob(in_dir + "/*")
ratio = 1024 / data_shape[0]
#data_shape = data_shape
output = 'image'
batch_in = []
batch_out = []
def calib_input(iter):
    np.random.shuffle(file_list)
    batch_in = np.zeros((batch_size,) + data_shape)
    if output == 'image':
        batch_out = np.zeros((batch_size,) + data_shape)
    elif output == 'label':
        batch_out = np.zeros(batch_size)
    for i in range(len(file_list)):
        with open(file_list[i], "rb") as f:
            #data = []
            max_reduce(data)
            cached_data[file_list[i]] = data
    #while True:
    for i in range(batch_size):
        f_ind = np.random.randint(0, len(file_list))
            #if os.path.basename(self.file_list[f_ind]) in self.cached_data:
            #    data = self.cached_data[self.file_list[f_ind]]
            #else:
            #    with open(self.file_list[f_ind], "rb") as f:
            #        data = pickle.load(f)
            #        self.max_reduce(data)
            #        self.cached_data[self.file_list[f_ind]] = data
        data = cached_data[file_list[f_ind]]
        ind = np.random.randint(0, len(data))
            #train_data = map(lambda x: block_reduce(x.toarray(), block_size=(self.ratio,self.ratio), func=np.max), data[ind].hL)
        train_data = data[ind].train
            #train_data = np.swapaxes(train_data, 0, 2)
        batch_in[i] = np.heaviside(train_data, 0)
                #gt_data = map(lambda x: block_reduce(x.toarray(), block_size=(self.ratio,self.ratio), func=np.max), data[ind].gthL)
            gt_data = data[ind].image
                #gt_data = np.swapaxes(gt_data, 0, 2)
            gt_data = np.array(data[ind].label)
        batch_out[i] = np.heaviside(gt_data, 0)
    #yield batch_in, batch_out
    #print(batch_in)
    return {"input_1": batch_in}
Re: decent pickle error
Hi @lzhao ,
I agree with you that it is more like a pickle issue than a DNNDK issue here.
I would suggest you to search on internet. You may find some useful posts.
Here is my two cents:
https://www.stefaanlippens.net/python-pickling-and-dealing-with-attributeerror-module-object-has-no-attribute-thing.html
Best Regards,
Jason
