decent_q command not found
Hi everyone,
Can you explain me the way to install decent_q? So I followed DNNDK user guide where it mentions "pip install ${DECENT_Q_TF_PKG} " so I did "pip3 install https://storage.googleapis.com/tensorflow/linux/gpu/tensorflow_gpu-1.9.0-cp36-cp36m-linux_x86_64.whl" and installed tensorflow successfully. But it still says decent_q command not found? How to install decent_q?
Btw, I'm using ubuntu16.04, cuda 9.0 and cudnn 7.0.5
@baharlabI believe that I made the same mistake.  Instead of using the Google wheel file from the web you should select the version that is included in the DNNDK tarball.  Here are the notes that I made during my last install.
--Quenton
--Quenton
Thanks! it works! I hope the doc is a bit more clear.
@baharlabI am glad!  Hopefully this post will help others who might encounter this.  If given the opportunity, I will absolutely share this feedback regarding the document....it cost me a bit of time as well!  Sorry about the trouble, and thanks for evaluating the solution.
--Quenton
Just to bring my 25 cents.
When installing Xilinx's Tensorflow in an off-line conda-environment the last pip install ... won't work without a local, off-line pip repository as well. What I did was:
# Using CPU, Ubuntu 18.04 and dnndk 3.1
pip install --no-deps tensorflow-1.12.0-cp36-cp36m-linux_x86_64.whl
# Install the remaining packages needed by tensorflow
conda install -y python=3.6 numpy opencv scikit-learn scipy progressbar2 protobuf absl-py keras
I haven't got it working all the way but I can at least do:
decent_q --help
Right now I'm stuck at decent_q bailing out with the following complaint:
"MyCondaEnvDir/lib/python3.6/site-packages/tensorflow/contrib/decent_q/utils/__init__.py", line 23, in <module>
ImportError: cannot import name 'DecentQTransformWithStringInputs'
Anyone having any ideas what the import failure is about?
I found another post  about ('DecentQTransformWithStringInputs') but without resolution.
/Nils
Ok, I got it working. It seems that conda installs tensorflow 1.14 on top of Xilinx 1.12 version. So swap the two statements in my previous post, i.e.
   # Install the packages needed by tensorflow
This will also install Tensorflow 1.14. To fix this, install Xilinx 1.12 version:
This should remove TF 1.14 and replace it with Xilinx's TF 1.12. I got decent_q running and right now I'm processing the resnet50 example included in the TF1.12 package.
Some feedback to Xilinx:
- As other have also stated, the documentation can be clearer and of better quality.
- The way your documentation suggest installation introduce an unnecessary dependency on a PIP repository. As I have demonstrated above, you only need to use PIP to install the wheel package. Conda can be used for everything else.
/Nils
Here is another cause of this bug: The tensorflow 1.9 and tensorflow-gpu 1.9 distributed in the dnndk 3.0 Xilinx wheel availaible here https://www.xilinx.com/products/design-tools/ai-inference/ai-developer-hub.html#edge differ from official tensorflow==1.9 and tensorflow-gpu==1.9 modules
Make sur that tensorflow or tensorflow-gpu 1.9 are not installed, only install the xilinx wheel with pip as explained above, else pip will happily falsely declare the installation complete, since a module with the same name already exists ...
Since Xilinx distributes a modified tensorflow module, wouldn't it make sense to rename it ?
Best regards
