difference in performance when using dpu integration tutorial
I am using dpu integration tutorial to run vgg16 model on zcu102. I built the hardware and petalinux using tutorial. I am using dpu2.0 version, 3 core design and low dsp configuration.
But when I use already provided image for zcu102 (xilinx-zcu102-prod-dpu1.4-2018.3-desktop-buster-2019-04-24.img.zip ) to run the same model, the profile graph shown is different as shown in figure 2.png
The question is that why there is difference in the performance. I expected same result in both the cases
Shikha Goel
(Ph.D. , IIT Delhi)
Re: difference in performance when using dpu integration tutorial
Can anyone provide any help on this. I think there is some problem with the driver code. In first image, vgg16 task is only scheduled once on core 3, but in second image, the task is scheduled equally on 3 cores. Why is this happening.
I am building hardware file and petalinux from scratch using dpu integration tutorial in 1st image.
Whereas in 2nd image, I used already provided image for zcu102
Any help on this?
Shikha Goel
(Ph.D. , IIT Delhi)
hello
do you see the same problem on latest DPU and DNNDK release?
I have just tried Resnet50 first on the TRD design generated image  zcu102-dpu-trd-2019-1-190809.zip and then on petalinux-user-image-zcu102-zynqmp-sd-20190802.img.gz : the behaviour is very similar.
The problem to try the latest trd is that we dont have dpu driver code available for it. As it is written in dpu integration tutorial that it is for dpu version 2.0
Where can i get the dpu driver code for latest trd?
Shikha Goel
(Ph.D. , IIT Delhi)
The DPU driver code is delivered with the TRD.
Terry
Sir,
I checked the behaviour with dpu version 3.0 as well. It is similar to what I observed in version 2.0
Shikha Goel
(Ph.D. , IIT Delhi)
Can anyone provide help on this?
I am still stuck at this performance problem.
Shikha Goel
(Ph.D. , IIT Delhi)
