dnnc "shitf_cut >= 0" failed when compile ssd mobilenet v2 converted from original tensorflow model
Environment
cuda: 8.0
cudnn: 7.0
caffe: chuanqi's  fork (with relu6 implementation)
dnndk: 20190624 version
decent: 1.2.5
dnnc: 2.05
dpu target: 1.4.0.1
Problem
I downloaded ssd mobilenet v2 from tensorflow's model zoo and converted it to caffe model(float.caffemodel and float.prototxt) using tool provided by chuanqi. "decent.sh" excuted successfully and generated deploy.caffemodel and deploy.prototxt(provided in txt format) I encounter this problem when ran "dnnc.sh":
Do you guys have any idea about this error? Thanks in advance.
Best regards
jcory
Hi @chuanliang.xie@gmail.com,
Please see the following post as a response to a similar problem:
https://forums.xilinx.com/t5/Deephi-DNNDK/An-error-about-DNNC/m-p/995339#M1510
I'm not sure what the equivalent approach would be in TF to combine BN+Scale layers, but it may be that a similar solution would apply if the root cause of the problem is the same.
Thanks and hope this helps,
-JC
