YilinChen
docker: Error response from daemon: pull access denied for xilinx/vitis-ai-gpu
Hi, guys
I am just met an error output when i try to use "./docker_run.sh xilinx/vitis-ai-gpu:latest" to boot docker environment for Vitis AI in GPU
but i get an error like this
after i try it again by running "./docker_run.sh xilinx/vitis-ai-gpu:latest" under "su root", but the error is the same like above
if there has somebody who share the same experience with me? I can make sure my network is ok
waiting for response online, thanks
graces
You need to build the GPU docker image before run the docker.
cd ./docker
./docker_build_gpu.sh
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
YilinChen
Hi, graces
thanks for your response
actually, I have run these commands yet
cd ./docker
but I can not make sure if the installation is success or not.
i have run both "./docker_build_gpu.sh" and "./docker_build_cpu.sh", I have run both of them under a "su root", after I running "./docker_build_cpu.sh", the very end is just like this
because it return a non-zero code:4, so I believe there have some errors. but because there has no red highlights, so I can not find where the errors come from.
and the output I got by running a "./docker_build_gpu.sh" is similar to the output above, for make sure of it, I will run "./docker_build_gpu.sh" again at night and send screenshot to you.
could you please provide some additional suggestion for me?
thanks a lot:)
dsp81
You can see the docker images that are installed by running the commands
docker images
OR
docker image ls
YilinChen
Hi, dsp81
thanks for your instructions, i am just input what you suggested and get output like this
per this output, if i can assume that my "./docker_build_cpu.sh" is success and "./docker_build_gpu.sh" is failure?
Thanks again
dsp81
I don't think either succeeded.  The two <none> entries are probably the failed builds.  Part of the reason I suspect that is due to the CREATED dates.  The xilinx/vitis-ai-cpu:latest image was created 7 months ago.  If you built it using the docker_build_cpu.sh script then it would show a newer CREATED date.
Additionally, the xilinx/vitis-ai-cpu:latest image on your machine has an IMAGE ID of 798f6eaea389, which is the same as the prebuilt 1.1.56 vitis-ai image that corresponds to Vitis-AI v1.1.  The image with the a7eb601784e9 tag corresponds to the 1.2.82 prebuilt image.
YilinChen
Ok, thanks
for fixing problems mentioned above, I think i need run "./docker_build_cpu.sh" and "./docker_build_gpu.sh" again until the two <none> entries disappeared, is that right?
and in addition, my current Vitis AI package's edition is 1.2.1
graces
You may also try to remove the seeming incomplete images and rebuild the gpu docker image from scratch.
docker image rm <image ID>
zhijiexu
hi, @YilinChen
There must be some errors when you run docker_build_gpu.sh. I believe you need to check the error information print in the terminal.
 You need to provide more information to let me know what's wrong, like you install steps, did you add related repository and key?
You need read https://docs.docker.com/engine/install/
hope it can help you!
YilinChen
Okay, i will take a try of it, thanks:)
watari
Hi @YilinChen
Since you got error no 4 (Interrupt system call), docker couldn't build image.
In this case, I guess your network was unstable. So, wget couldn't get proper image from Internet.
Would you make sure your network ?
As you know, docker puts a heavy load onto network during build flow with Dockerfile.
So you might retry this flow until success.
YilinChen
hi, zhijiexu
thanks for your response, i think my docker is ok, because i can run "docker run hello-world" without sudo
and i just try to run "./docker_build_gpu.sh" under a "su root" again, in the very end i get error output like this
so how can i deal with it now, appreciating for any help, thanks a lot
watari
Hi @YilinChen
It seems proxy issue.
Would you make sure your proxy setting or your network ?
YilinChen
Okay, watari
I also think sometimes there have some unstable effects on my network, so i just try to run "./docker_build_gpu.sh" under a "su root" again, in the very end i get error output like this
there still have some problems, appreciating for any support, thanks a lot
zhijiexu
hi, @YilinChen
thanks for you reply.
For this issue, like @watari  post before,  you need to check you internet speed.
if you download in china, you can change the source, or you can try to increase the time-out time
Hope it can help you!
YilinChen
yes, watari,
currently i am in china, sometimes i will open my VPN to download some resources, but i just run "./docker_build_gpu.sh" under a "su root" in a VPN disconnected environment.
And in addition, if there is a VPN connected environment, i can open google or youtube quickly, but the running of "./docker_build_gpu.sh" can not access to the network, the screenshot is like this
YilinChen
hi, watari
i have another question for you.
because i find that i can run "./docker_run.sh xilinx/vitis-ai-cpu:latest" successfully without sudo like this
if that means my running of "./docker_build_cpu.sh" is successful? if it is successful, why there have two <none> here(just under REPOSITORY and above docker)
just waiting for your helps, thanks
YilinChen
hi, zhijiexu
followed the question for watari above, i have a confusion for this screenshot
there are information like this
Docker Image Version: latest
Build Date: Wed Nov 4 20:36:57 MST 2020
VAI_ROOT=/opt/vitis_ai
For TensorFlow Workflows do:
conda activate vitis-ai-tensorflow
For Caffe Workflows do:
conda activate vitis-ai-caffe
For Neptune Workflows do:
conda activate vitis-ai-neptune
More detail on conda packages included in container: /opt/vitis_ai/conda/conda_packages.txt
More detail on other 3rd party package source included in container: https://www.xilinx.com/products/design-tools/guest-resources.html
As the bold part indicated, there should have a vitis_ai folder under the folder of opt,
but actually, there has no vitis_ai in opt
just wait for your response, thanks a lot
watari
Hi @YilinChen
If your account have same group id or same privilege, you can launch docker command without root privilege.
Would you make sure it in /etc/passwd and/or /etc/group, if you want to know details ?
Because of lack of tag by ex. your flow or mistake or wrong tag, you can see <none> on "docker image ls".
Would you try to login with /bin/bash by docker command on <none>'s docker container image, if you want to know detail ?
zhijiexu
hi, @YilinChen
Thanks for your reply,
For your another problem, you want know where is the /opt/vitis_ai?
Actually, It is the directory in docker image, you can run docker.sh <>, and print command "cd var/vitis_ai" to find it,
but totally, I think it is not necessary
Best regard,
Zhijie
YilinChen
hi, watari
as this part
i remembered that i use the shells shown below to make sure running "docker run hello-world" without sudo
that is also come from the instructions of tutorial shown below
and in the files of /etc/passwd and /etc/group i can find names just like "root" or "shixian".
YilinChen
and as this part
please provide some more details about "lack of tag by ex", i think i can not fully understand it.
YilinChen
exactly, that is a truth
thanks a lot!
watari
Hi @YilinChen
As I already mentioned before, if your flow is wrong or mistake or you attach wrong tag in procedure, you can see <none> on "docker image ls".
# Procedure (a part of example)
1. delete tag information in docker image files before building procudure, if there is already same tag.
2. build docker container with Dockerfile.
3. If building procedure is failed, you can see <none> on "docker image ls".
Hope your helps.
