dpu version 3.0 using petalinux 2019.1
I am using petalinux version 2019.1 to build system using for dpu version3.0.
I could generate .hdf file using vivado 2019.1
Then I am using petalinux to build the system. But petalinux is throwing the following error.
Problem: conflicting requests
- nothing provides libm.so.6(GLIBC_2.27)(64bit) needed by dnndk-1.0-r0.plnx_zynqmp
Any help on this?
Shikha Goel
(Ph.D. , IIT Delhi)
Re: dpu version 3.0 using petalinux 2019.1
Hi @anz162112 ,
Have you tried the step to step flow to configure and build the PetaLinux project?
https://github.com/Xilinx/Edge-AI-Platform-Tutorials
It would add several package groups to rootfs. Maybe the missed lib is inside there.
Best Regards,
Jason
Yes, I followed it step by step. I tried many a times. But dont know why this error is coming.
Shikha Goel
(Ph.D. , IIT Delhi)
Hi @anz162112 ,
I tried to search the file in my test project, generated follow the flow I have just posted and can find the file here:
root@zcu102_dpu_test:/# find -name libm.so.6
./lib/libm.so.6
Would you please send me a email address by private message?
I can send you my PetaLinux test project by Xilinx EZMOVE and you can compare the difference here.
Best Regards,
Jason
