kohsenglee
error running SDSoC 2018.3 DNNDK demo on ZCU102
I am facing issues running SDSoC 2018.3 DNNDK demo. Wondering if anyone can help to advice.
I am getting the error below. The libdputils.so is in the correct directory /media/card/lib
root@xilinx:/media/card/scripts# ./run_gesturedetect.sh
(gst-plugin-scanner:2666): GStreamer-WARNING **: Failed to load plugin '/media/card/lib/libdputils.so': /media/card/lib/libdputils.so: undefined symbol: dpuGetInputTensorScale
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: Could not get allowed GstCaps of device
Additional debug info:
../../../git/sys/kms/gstkmssink.c(1037): gst_kms_sink_start (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0:
driver does not provide mode settings configuration
Setting pipeline to NULL ...
Freeing pipeline ...
root@xilinx:/media/card/scripts# ls /media/card/lib/libdputils.so
thank you!
Chris
dehim
I get the same error. Have you solved this?
kohsenglee
Hi Dehim,
Yes I have. the demo is run off HDMI port, not display port.
Chris
dehim
Hi Chris,
Thanks for your reply.
I know the demo uses HDMI. It had to do with my monitor. I grabbed a different monitor and it works now.
-Dehim
kingkoyan
Can you describe in more detail how to solve this problem? did you use usb Camera?
chocolove2811
I use upper HDMI port on ZCU102 to connect display. You need USB camera for facedetect (others demo does not need USB camera).
The warning message still appear, but each demo is running with no probrems except this message.
(gst-plugin-scanner:2644): GStreamer-WARNING **: Failed to load plugin '/media/card/lib/libdputils.so': /media/card/lib/libdputils.so: undefined symbol: dpuGetInputTensorScale
