dvukadin
how to run tiny_yolov3_416 with DpuTask when there are multiple subgraph after compiling model (VAI 1.3)
I am trying to run tiny_yolov3_416 with DpuTask::create on VAI 1.3, but I don't know how to implement DpuTask functions for calling multiple subgraphs.
After compiling, there are two sugraphs of tiny_yolov3_416 and I am not sure how to implement them.
The following example does not work:
auto task = vitis::ai::DpuTask::create(kernel_name) // kernel_name = "/usr/share/...../tiny_yolov3_416.xmodel"
task->setImageRGB(image);
task->run(0u); // run only subgraph[0]
auto output_tensor = task->getOutputTensor(1u); // get output tensors from subgraph[1]
I think I need to get output tensors from sugraph[0] and set them as input tensors of subgraph[1] and run subgraph[1] but I don't know how to do it.
Any help would be appreciated.
dvukadin
jheaton
Are you saying that you have 2 DPU subgraphs? I would not expect that for TinyYolov3.
Can you share the compiler output.
If you are converting from Darknet to Caffe, there is a layer change you need to make to compatible with the DPU.
dvukadin
Yes, I have 2 DPU subgraphs. I am converting tiny_yolov3 from Darknet to Caffe with the script: Vitis-AI/models/AI-Model-Zoo/caffe-xilinx/scripts/convert.py (branch: v1.3)
I only had to change "stride=2" to "stride=1" in [maxpool] at 92.-96. lines.
Please find attached the compiler output.
Thanks!
