install DNNDK in virtualbox
在虚拟机virtualbox上运行install.sh文件去安装DNNDK时,进程卡在‘Begin to install Xilinx DNNK tools on host...’,卡在这里不动了。
When I ran install.sh in virtualbox to install DNNDK, my processing stopped at the step that 'Begin to install Xilinx DNNK tools on host...' and never move on any more.
Re: install DNNDK in virtualbox
Use sudo command.
sudo ./install.sh <board_name>
Regards, abhidan@logictronix.com
Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos if you think it was helpful and reply oriented.
Use sudo command.
