install xilinx DNNDK pkg-config command not found
Re: install xilinx DNNDK pkg-config command not found
@yanxiaopan Please try:
sudo ./install.sh ZCU102
--Quenton
I have the same problem with @yanxiaopan and it is still not working:
root@petalinux_proj:~/ZCU102# ./install.sh
Begin to install Xilinx DNNDK ...
Install DPU Driver ...
Install DNNDK tools, runtime & libraries ...
./install.sh: line 64: pkg-config: command not found
Installation failed!
root@petalinux_proj:~/ZCU102# ls
install.sh pkgs
root@petalinux_proj:~/ZCU102# sudo ./install.sh ZCU102
-sh: sudo: command not found
root@petalinux_proj:~/ZCU102# ./install.sh ZCU102
root@petalinux_proj:~/ZCU102# ./install.sh zcu102
