issue when run docker gpu
Hello, when I am using ./docker_run.sh xilinx/vitis-ai-gpu:latest, it shows that:
docker: Error response from daemon: Unknown runtime specified nvidia.
However, I have followed all the instructions on:
https://github.com/XilinVitis-AIx/
building and installing NVIDIA Docker Runtime, why should this happen?
I am using Ubuntu 18.04 and RTX2080
how can I fix this?
Thank you very much!
With the latest version of docker, the call is slightly different and you may have to modify the call to "docker run" inside the docker_run.sh script.
Inside the "elif" block, remove
--runtime "nvidia"
replace it with
--gpus 'all'
Instead of 'all' you can use a specific GPU in your system, it will correspond to the numbering inside nvidia-smi.
