@xx
os image zcu104
i flashed 2018-12-04-zcu104-desktop-stretch.img to sd ,boot zcu104 ,the lights are on ,but the monitor doesn't have reaction.
qhall
@xxAre you attempting to connect a DP or HDMI monitor?  Perhaps try executing xstart& from your terminal and see if the monitor comes up when you do.
meherp
I saw the same issue as well with some of the monitors (using DP port)
I connected the different monitor to board to resolve the issue.
We found that certain monitors do not work well for ZCU102 and ZCU104 boards.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
tongtyr
HAVE you solved this problem?
I met this problem,too
@xx
Check whether the interface is correct, or change the display
