YilinChen
run "./docker_build_gpu.sh" without "su root", but because of permission related issues, it failed
hi, guys
i just try to run "./docker_build_gpu.sh" without "su root", but because of permission related issues, it failed like this
but as shown below, i can run "docker run hello-world" without sudo
is there anyone who can help me to deal with this problem?
appreciating for any help, thanks
zhijiexu
hi, @YilinChen
For you question post above, I believe you can try to use command " sudo ./docker_build_gpu.sh" to install the docker-gpu, then use command to make you become a no-root user.
thanks,
zhijie
YilinChen
okay, i will follow your instructions and try it again, thanks
YilinChen
hi, zhijiexu
i just try to run "sudo ./docker_build_gpu.sh", but the result is same to "./docker_build_gpu.sh"
and after i try to run shells like these in an VPN connected environment
the output is shown below
and after i disconnect VPN and run "./docker_build_gpu.sh" under "su root" shown below
it seemed like the installation is on the way
and there will be a long-waiting-process, after nearly an hour, the output is shown below
how weird it is!
how weird it is!
how weird it is!
watari
Hi @YilinChen
From your log, it seems DNS issue.
So, would you make sure resolver setting ?
I suggest you to make sure resolver setting and status by the following command on the host machine.
$ dig www.xilinx.com
Would you try it ?
